Results 1 to 15 of 15
Thread: My new Fat Cat
    Oct 2008
    Sudbury,ONTARIO
    21
    My new Fat Cat
    Hi all,
    new to the forum and thought I'd ask a few questions. I just purchased a sweet Tr200 AKA the Fat Cat. I have been able to find brand new OEM fenders here in Canada honda Canada still sells them
    My question is what tires are you guy's running on the Fat Cat? Mine are original and should be changed but can't find the tires in 24.5x8-11 and 23.5x8-11. They where Dunlop's back in the day. I live in Northern Ontario and run mostly trail with mud rocks and snow.
    She runs great,
    Perry
    N.E. Ohio
    2,005
    just run something close...I usually go to the dealer and cross reference with whats new out of their catalog. Sometimes I order from them and sometimes I shop it out.
    Oct 2008
    Sudbury,ONTARIO
    21
    Talking
    Thanks for the input. I went with the Carlisle 489 in 23x8-11 I will have it mounted on Monday
    Any know how to turn up the idle on the bike. She will not idle very well and sputters when running. I suspect the gas is old and the carb might be gummed up. I will drain the tank fill with fresh fuel and add some carb cleaner to the gas and take here out for a good ride.
    My Honda repair manual is on the way but I'm not sure what needle to turn for the idle
    Look forward to my first ride on Saturday. I will take pics,
    P
    Sep 2007
    100mi west of Chicago
    3,582
    There should be a screw with a spring behind it, most likely on the right hand side if it's like other Honda 200 carbs. Turn it to the right to turn the idle up.
    Rob
    Oct 2008
    Sudbury,ONTARIO
    21
    Hey thanks Rob. I will check it out tonight
    P
    Oct 2008
    Missouri
    15
    Nice Fatcat ...I just got one on Monday, and haven't even seen it yet as my brother picked it up for me, so I go get it on Saturday...I will be needing fenders for it, and saw where you mentioned that you got new OEM ones...does that dealer have any more, and how much were they? I am in the US, but my dealers here tell me that they can't get them any longer. I also need a new set of bars as the originals have been broken and welded back together.
    Thanks and enjoy the Fatcat
    Jason
    wales..uk
    1,318
    Hi i did a restro on my fatcat last year.....you can still get the front and rear fenders from honda... headlight and side covers are a different matter.....
    Also the tires... i found this Maxxis tire which is 23x8-11 http://specialtytiresstore.com/all_track_atv_tires.htm which is the closest size you can find for the back....the front you can still get from honda...
    http://www.3wheelerworldforums.com/s...ghlight=fatcat
    Need Honda ATC TRX NOS restoration parts??? or come check out our ATC brochure site
    www.offroadvintage.com
    Oct 2008
    Sudbury,ONTARIO
    21
    Holly *Edited**Edited**Edited**Edited* Pete! Now that is over the top. How hard was it to tear the bike down to the frame?? Did you put everything in labeled boxes and start from front to back.
    I'm no mechanic but can build RC Helicopters from scratch in two day's I have the Honda repair manual coming in on Tuesday.
    This looks like a fun winter project,
    P
    Oct 2008
    Missouri
    15
    So, "Petesact" and "Canucksfatcat", what do I need to check for or ask when calling Honda about the fenders? I checked with the Honda dealers here in Kansas City, MO/KS, USA and they tell me that they can't get them any longer. So I guess from your messages, they are available, but I just don't seem to be calling the right places I guess. If you know of a dealer that can get them, can you send me their name/number and location? I will call them if my local ones won't help me out.
    What are the specs on the handlebars...I assume they are 7/8" bars, what is the rise on them and how far back is the bend on them? I probably will just look to put on some aftermarket dirtbike or atv bars as opposed to trying to find an original set, unless I can locate originals one of these days.
    So, Pete, how did it take you to do the full restore on it? I am going to do the same, but may not go back 100% original...may even do an all black version wth the yellow/orange stickers and some custom paint/airbrushing. Maybe some Tiger stripes to match my 2006 Triumph Tiger!
    BTW...what size is the front and rear tire supposed to be anyway? I don't have a manual or anything, and don't know if the ones on the bike now are the right/original size anyway.
    Thanks,
    Jason
    Oct 2008
    Sudbury,ONTARIO
    21
    Smile
    23.5x8-11 rear
    24.5x8-11 front
    Those are the correct tire size. I purchased my Fenders in Canada. Not sure If that makes a difference. You can contact RL Equipment in Verner Ontario and talk to Bob in parts to get part numbers.
    Hope that helps,
    P
    wales..uk
    1,318
    Quote Originally Posted by canucksfatcat View Post
    P
    Hey Perry,
    it was pretty easy to do the restro easier than a atc restro...buy yourself a workshop manual and get going....
    only problem.... parts are getting thin on the ground you need to search high and low for some of them...
    Pete
    wales..uk
    1,318
    Quote Originally Posted by jsingraham View Post
    Thanks,
    Jason
    Hey Jason,
    i got my fenders from Andrew Hyman this is him http://cgi.ebay.com/ebaymotors/HONDA...d=p3911.c0.m14
    email him and ask him if he's got any in stock if not he'll order them for you...
    my restro only took 2 weeks but i found nearly all the parts before i started..
    Pete
    ovhonda1's Avatar
    ovhonda1 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Sep 2005
    Louisville, KY
    369
    There is usually a guy on ebay that selld NOS fenders. That is where I got mine from 2 years ago for my restoration. Fork boots are hard to come by becasue they are really small (like a CR 80). And by the way, check the tank for rust inside, they are known for that. I used redkote on mine and it worked great. Good Luck
    Attached Thumbnails Attached Thumbnails 3whlr family-oct20007 026.jpg   3whlr family-oct20007 027.jpg
    Oct 2008
    Sudbury,ONTARIO
    21
    Thought I would post what I have done so far.
    Replaced Front and Rear Fenders
    Removed and cleaned carb 3 times. Still hesitating on he top end Idle and blaps around like a champ though. Plug looks like it's running a little lean
    Replaced Rear tire
    Removed original rear bearings. I could not spin them with my hands.
    Replaced rear brakes as the originals where glazed
    Shorty brake levers
    Fox Racing blue crossbar pad
    New tail light
    Replaced original chain,sprockets
    Replaced air filter
    Replaced Plug
    Fresh oil change
    new front tire on order and front bearings
    ordered a Gasket kit for the carb. Hope that helps!?
    Honda repair manual on the way
    I'm looking for a rear Rack but having trouble tracking one down. Fun bike to ride here in Northern Ontario.
    P
    Feb 2008
    hazard, kentucky
    59
    i ran with two 200x front tires on mine, 23X8X11, smooth ride wanna sell it
