Results 1 to 15 of 15
Thread: 27" front tire Big Red
    Apr 2008
    Manitoba Canada
    106
    Well, I installed a 27" tire on my BR today, a 27x10-12 Mudlite (kind of agressive but all I could find locally). Between the tire and the rear lift I gained about 1-1/2" of ground clearance at the belly. The tire is 26" tall on the rim, 3" taller than the so called 25x12-9.
    Here is a couple of pics. I'll have some better pics later.
    1985 Honda Big Red 250ES
    27x12-10 Mud Bug rear tires on ITP aluminum rims
    27x10-12 Mudlite on front
    Jul 2006
    cool!!! I want another 250 es!! what rim is that off of? im making notes!! thats the direction I want to go with when I get another.
    NE Arkansas
    2,344
    Yeah, what offset is that wheel? Any pics of the brake side of the wheel?
    My Rags
    Apr 2008
    Manitoba Canada
    106
    The rim is an ITP Delta steel wheel, 12x7, 5+2 with 4/110 bolt pattern.
    Like this http://www.casterland.com/webstore/p...d=2663&sub=235
    Bartlett TN
    3,083
    Those are just like the ones I got from dennis kirk for my rear. I need to get one for the front too as my 26 rears are alot taller.
    86-87 Tecate ROCK!
    Apr 2008
    Manitoba Canada
    106
    Quote Originally Posted by ScottZJ View Post
    My next set of tires will be 26 or 27 for the rear.
    Does your rim have 8mm or 10mm bolt holes? Mine are 10mm, so I am going to have to find a spacer or bevelled nuts as the studs on the Big Red are 8mm. I centered them and tourqed them down good for now.
    1987350x is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2007
    Winnipeg, Canada
    267
    Hey 01ps,
    Where are you in MB?
    My Trikes: Past and Present
    1985 Yamaha TRI-Z
    1985 Kawasaki Tecate KXT250 (x2)
    1986 Honda 250R
    1986 Honda 350X
    Bartlett TN
    3,083
    Well my 87 big red already had the tapered lug nuts so it worked fine with the rims I got.
    86-87 Tecate ROCK!
    Apr 2008
    Manitoba Canada
    106
    Quote Originally Posted by 1987350x View Post
    Hey 01ps,
    Souris, south of Brandon
    Apr 2008
    Manitoba Canada
    106
    Do you know if all 87's have the tapered 8mm nuts?
    Bartlett TN
    3,083
    Well the 86 and 87 Big red and SX's had them, then the 86 250r and 86 350x. Now there might be more that had them but those are the ones I know of.
    86-87 Tecate ROCK!
    Maryland
    3,077
    Is that a mudlite AT or XL?
    Apr 2008
    Manitoba Canada
    106
    Do you happen to know where I could get 4 of them, or do you have a Honda part#?
    I can't find an 8mm beveled anywhere locally, and honda is not sure the one listed in their parts book is actually bevelled. Besides, they want $6.00 each, so an aftermarket would be nice.
    Bartlett TN
    3,083
    Well there are some on egay...........
    http://cgi.ebay.com/ebaymotors/HONDA...spagenameZWDVW
    86-87 Tecate ROCK!
    Apr 2008
    Manitoba Canada
    106
    Quote Originally Posted by TravEX View Post
    Here are some more pics, sorry it took so long.
