i purchased a cobra exhuast for my sx, but i didn't intend on it being insanely loud like it was, so what i did was went down to the local tractor supply company and bought a canister muffler for a 1976 international farmall tractor, and it worked great! much better at full throttle without sacrificing flow, i just took the bracket off the cobra muffler and welded it on. i used the cobra front pipe( becuase it's larger than oem and cut the cobra muffler of and put the tractor muffler on, for 30$ anyone can do this and it's cost effective, you don't have to use a cobra front pipe u can just use your factory front, thought i would share that with every sx owner, also if you want a ignition upgrade rick's performance makes a hot cdi for 70$ it provides multiple spark and has a increased red line of about 1000rpm, but unfortunatly the stock sx cam is done at that rpm, but if you put a bigger cam in it you can use that rpm for a higher top speed! only downside i noticed is that once i put it on my bike ran rich due to the multiple spark, so i put a stock main jet back in it and it run's like a cheetah on cocaine for a sx.
