I am looking at buying a 200x carb to fit on my ATC 185, does anyone know if this is a straight swap?
Will I need the intake manifold and air filter tube off the 200x, or will the 185 ones fit?
Thanks for the help
Jason![]()
Thanks for the help
Jason![]()
I am almost positive it's a direct swap. I don't remember which intake tube I used.
85 200x - Torn apart
i tried to swap the carbs on a 200es and 200x same years and all but the hole on the carb and intake where different so it wouldn't bolt up for me.
If it's a stock 200x carb, it will bolt up to the 185 intake boot with no problem, (i've mounted my 185 carb on a 200x intake boot, and it fit perfectly) but i think the inlet of the 200x carb might be just a bit larger diameter. You might have some trouble getting the airbox tube on the carb, but it should go on.
83 185s *Now belongs to my nephew*
83/84 200x
85 Tri-Z
85 350X
85 Tri-Z Parts Donor
88 Yamaha Moto-4
