big red 200 rear break axel nuts
Them lil pain in the harse nut's stripped out one me, well one did anyway, jst wounderin any of you guya had the same lil problem. I went to the nut and bolt shop, and they don't have them there. i also went to te scrap yard and looked at some hub nuts of some fords, they suppose to be aroud teh same size, but the treads are diferent. I would retap the treads so a couple new nuts would fit good but a 31 or 30 mm tap is hard to find. i think i just might wack j-b weld on the treads, place the stripped nut in first then the outta nut and tighten it. or i might use tread locker.
1984 Honda Big Red
found a set of a buddys scrapped 200s
1984 Honda Big Red
//ArrowChat Integreation Code
