Results 1 to 7 of 7
Thread: 350x engine rebuild questions
    Jonpin's Avatar
    Jonpin is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2008
    Melbourne Florida
    333
    Lightbulb 350x engine rebuild questions
    Im going to be rebuilding 2 350x engines ,is there any thing i should realy know befor i start doing this ,one im just doing a top end on the other im changing out the center cases on "thats the one im kinda scared of" i did a top end rebuild on my 200e wasnt bad at all but i want to make sure its right the first time .any pistons i should look to buy i was looking at the wiesco ones on ebay ,i still dont know what the bore size is yet so i cant buy the pistons yet ,how do i know if the timeing chain should be replaced ,any way to know if the valves are seated good ,ill be changing the valve seals as well "any tips on how to do that" i do have the manuel to" how do i know if the oil pump is worth a . sorry theres alot of questions but im very scared of messing something up .
    05 Kingquad 700 85 200x 85 250es 85 350x
    85 350x rider project 85 350x (project) watch the progress here http://3wheelerworldforums.com/showthread.php?t=85959
    Goin to prove you can polish a turd "so far it takes a lot of cash to buff that brown out'
    PA
    3,515
    as far as the oil pump, they are over looked most of the time.
    open it up and see if its tore up on the inside. 3 little screws is all it takes to open one up.
    as far as the motor, its no different then any other motor. lap the valves and check with liquid or a even a flash light to see if they seal.
    WWW.HREATV.COM
    Texas 200x is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Corpus Christi, Tx
    296
    If your spending the money time and effort to rebuild the motor, just put in a new oil pump. That way you won't have to worry about it. The oil pump is one of the MOST important things in your engine. As SWIGIN said you can look at the inside. Any kind of roughness or grooves is wear. You lose a little pressure out of the those grooves and eventually it will drop to low.
    Hey, What other dangerously fun vehicles can I Cram in my 2and1/2-car shop? (Garage.)
    Nov 2004
    Waterloo IL
    2,701
    So oil pumps are known 350X problems? I'm not even sure where it is located and can I check it without pulling the engine apart? Like if I want to check mine right now with the bike completely together.
    08 Outlaw 525s
    07 CRF70
    04 Harley FLHRCI
    04 TRX90
    03 XR650R
    03 400EX- XR650R engine
    02 XR100R
    01 Banshee
    00 XR50R
    00 XR70R
    99 PW50
    99 JR50
    96,95 Sportsman 400
    95 Xplorer 400
    94 Indy XLT
    87 Trail Boss
    86,86,86,86,86 Scrambler
    86 TRX70 x2
    85 ATC350X
    85,84 ATC250R
    85 Red Tecate
    85 LT50 x2
    84 XR500R
    84,84,84,84,83,82,80,79 ATC70
    82,79 XL500R
    83 ALT50
    79,78,77,77,76 XT/TT500
    76,75,74 XL70
    72,71,71,71 SL70
    72 Harley FX
    72,71,70,70,70,70,70 CT70H
    72 SL100
    70,69 Z50
    PA
    3,515
    all old 4 strokes need the pumps looked at IMO.
    its under the clutch cover
    WWW.HREATV.COM
    Yes yes yes!! I got a brandy new one for 45$....
    Gotta get the fresh oil up there!!
    I think the 350X pump is discontinued now though?? But I thought there was one you could modify to work like the 300EX or something??
    Dec 2005
    Wisconsin
    1,141
    Dirtcrasher where did you get your pump from? I want to get a new one or rebuild the one in my 200x when I do my engine work.
    YTM-200, Wheeling machine!!!
    1985 Honda 200x...
    ...Just a simple mild 200x
