Results 1 to 15 of 26
Thread: Auto-x 11-14 done (for now) pics added
    Aug 2005
    SW Iowa
    524
    Thumbs up Auto-x 11-14 done (for now) pics added
    first to those of you that I inquired parts about I appologize I am recently unable to make extra purchases at this time I do appreciate your time and thank you all.
    So last night I decided to quit thinking about it and just start.
    I've read that the 200s convert is relativly simple but as stated I'm using my 85 200m engine in my 84 200x frame I know at least one other person has done this an I'm trying to find out who and what thread I saw it in haven't found it yet.
    So far I think I will need to dimple the front down tube and mod the brake pedal.
    Also I'll need to figure out where to mount my added elect. hardware.
    I've got both engines removed and today I'll try and get the auto engine in and post pics as I go along. Any tips or advice is helpful thank you.
    Attached Thumbnails Attached Thumbnails Copy of 200_autox_build_10-24-08 001.jpg   Copy of 200_autox_build_10-24-08 002.jpg   Copy of 200_autox_build_10-24-08 003.jpg   Copy of 200_autox_build_10-24-08 004.jpg
    Sep 2007
    100mi west of Chicago
    3,582
    What exactly is an Auto-X? I've seen it mentioned on here but I don't know what it means. I'm guessing some sort of hybrid? What is the purpose of doing it?
    Rob
    Aug 2005
    SW Iowa
    524
    the 200x has hand clutch the 200s and m have semi auto drives. I guess most often done for the convenience of not needing to hand clutch. I'm doing because
    1. the x engine needs rebuilt and the m runs fine
    2. I like to do more trails/woods riding than track.
    roger86200x is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jul 2003
    Western New York (Buffalo)
    348
    What is the difference between 200s, 200m, and 200e? I knew at one point but it got over written with something else lol...
    1984 Honda ATC 250r
    Bored .020 over Wiseco, Answer silencer, fresh motor, New connecting rod and balanced crank, Boyesen 2 stage power reeds
    Aug 2005
    SW Iowa
    524
    200-s no electric start , recoil pull start only
    200-m electric start
    200-e also electric start but it has a high low sub trans.
    Jul 2003
    348
    Quote Originally Posted by bigred1 View Post
    aha! The high low trans is what I 4got....
    Thanks!
    1984 Honda ATC 250r
    Aug 2005
    SW Iowa
    524
    doin some work on the engine today. Swaping the head and cam (maybe) I'm looking into the bad cam cause I might jsut replace the top end on the x and put it back in not sure yet..
    MO dx's Avatar
    MO dx is offline Just Too Addicted Arm chair racerJust too addicted
    palmerton
    532
    I did that same swap there should be pics of the build under my threads. Its a little harder then the S swap becuase of the starter hitting the frt tube and making a place to mount the battery and charging wires. But it can be done.
    Master of the DX and Pennsyltucky survivor ,08,09. Thats something to brag about
    Aug 2005
    SW Iowa
    524
    well I bought a small torch set and tried my hand at heating up the down tube to make room for the starter.I'm using a small bottle of map gas and oxygen didn't do so well though. I think I was to worried I would get it to hot and melt it. I've never done this kinda work before and used up my small bottle of oxygen. I'll get another one and maybe I'll have better luck now that I have a better understanding of how long it takes to heat up metal. It won't look as good as yours MO dx but as long as I can get the starter in I'll be happy.
    Dec 2005
    Wisconsin
    1,141
    Yeah heat that baby up cherry red. You won't melt it if you keep moving the torch. It will get real yellow/ bright just before it melts, just keep it at a nice red/ orange and you will be fine.
    YTM-200, Wheeling machine!!!
    1985 Honda 200x...
    ...Just a simple mild 200x
    MO dx's Avatar
    palmerton
    532
    Find a pc of pipe and practice heating and shaping that first. Then you won`t give yourself more work on x frame. I `ll try to give help where I can
    Aug 2005
    SW Iowa
    524
    I got the frame bent finaly deffinately does not look prety but it'll work.
    got the engine put in ( 85 200m lower end w/84 200x head/cam and a 200s valve cover) and I have 0 compression. So I put on a 200x valve cover and now have 30 pounds pressure.
    Is there a way to remove the valve springs without buying the valve compressor tool which is about 72$ where I checked?
    Sep 2007
    3,582
    I made my own valve compressor tool out of a socket with the side cut out and a c-clamp that you tighten by hand. You put the socket on top of the spring retainer and put the top of the c-clamp on top of the socket and the bottom of c-clamp on the bottom of the head and then you start to tighten the clamp so it compresses the spring. The side cut out of the socket gives you access to get your small screwdriver in there to pop the cotter pins out. I've used it on a couple heads including the YFZ I used to have. If this sounds confusing, which it did to me the first time I read it on a YFZ forum, I can post a picture tonight since I still have my 200x head on my workbench.
    Rob
    Apr 2004
    Brigham, Québec, Canada
    1,529
    Did you adjusted the valve clearence after switching valve covers?? Remember that because the cylinder to valve cover seal is silicone it greatly affect the rocker to valve position. JUst trying to help you.
    1984 Yamaha YTM-225DX
    Québec 3-wheeler riders group
    Aug 2005
    SW Iowa
    524
    Quote Originally Posted by rdlsz24 View Post
    Rob
    think I get it but if you could post pics that would be great.
    what size socket did you use?
