ok so im trying to get my girls blaster going again...(just havnt ran it in a few months) so I popped in a new plug (NGKb8es) and fresh premix 40:1 KLOTZ. and kicked and kicked... usually this thing fires up instantly... well it didnt... so I fidled with it some more... put in another plug and got it to fire... but after some time running... I cant get it to open up... It bogs down after half throttle.
Its running a 32 kehin it has ummm... I forget pilot running a 30 main and needle set at top clip.
the motor has a vitos 3mm stroker crank.. 60 over wiscoe and fmf pipe ct silencer twin air filter open airbox..
the last time it ran I knew it was running rich but kept running it... the plug from then was nasty rich black....ew...
its still a bit rich but I cant get it to rev out so whats the deal? did I junk 2 plugs allready? (my old 300R) could do that.
should I put in a b7es plug? (hotter)
the only other jets I have is a 45 for the main I dont think going bigger will help..., but could it possibly be a lean condition bog? when it bogs I can let off and it will go back to ideling perfect....
let me know homies!
I bet Curtis would let you twist the dunes on one of his rides....
Make sure you bring Ronnie, Gabe, Billy and wheelie king with ya....
