Page 3 of 3 FirstFirst 1 2 3
Results 31 to 40 of 40
Thread: Yamaha YTM Front Shock Disassembly How-To
  1. #31
    Mexico
    9,018
    Quote Originally Posted by onformula1 View Post
    Wow!, as usual Primo work.
    That trike is good looking.
    I know! Can you believe some guy on another thread wants me to cut it up and put a swing-arm on it!
    It sucks to get old
  2. #32
    Surprise, AZ
    2,428
    Some people's kids???
  3. #33
    tripledog's Avatar
    Aug 2011
    Central New York
    2,182
    You guys do nice work. Stick a fork on it, it's done.
  4. #34
    Surprise, AZ
    2,428
    Quote Originally Posted by tripledog View Post
    You are totally correct the forking around is over,,,, and now to Brembo disc brakes front & rear to match that WP shock.
  5. #35
    Jan 2013
    minnesota
    5,911
    If anyone has rust on any parts, one way to remove it is to buy some powdered/crystal 99% Oxalic acid and a plastic tub . Mix 1/2 lb of acid per 1 gallon of watter and let them soak until they are clean . This take from 1 to 4 days depending on the amount of rust . Mixing it at 1 lb per 1 gallon of water will speed the process up.
    Do this in a well ventilated area and do NOT breath the dry powder or the fumes from the mix . It is similar to battery acid in that it can make your hands sting slightly and burn holes in your clothes . If you get some on you simply rinse it off . The mix can be neutralized by adding around 1/8 cup of baking soda per gallon of mix at which point you could even drink it if you wanted . If you have a pool test kit, neutralize it to 7.5 - 8.0 ph . After this you can dump it in the yard but the rust can leave stains.
  6. #36
    Nov 2002
    Kirkville, NY
    3,831
    Man, 10 years later I'm pulling some YTM 200 forks apart wondering how I get the stupid seal out and remember I posted a how-to... I'm learning from younger me! I think I still have that homemade press in the shed someplace, time to dig it up!
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
  7. #37
    Mexico
    9,018
    Quote Originally Posted by thefox View Post
    On the 200 just remove the cap, spring and dump the oil. Then remove the retainer clip and washer above the seal. Lock the lower leg in a vice and use the upper tube like a slide to pop the seal out.
    If it won’t come come out use a heat gun to soften the seal and expand the lower tube and try again. I’ve had to use a torch on occasion, they can really be stuck in there at times.
    Be ready for it to let go in grand style when it does and make sure you don’t end up tossing the upper tube through a window or spearing your dog.
    It sucks to get old
  8. #38
    Nov 2002
    Kirkville, NY
    3,831
    The heat gun is a good idea. One shock is a little stiff (it must be slightly bent) so the slide method won't be easy.
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
  9. #39
    Mexico
    9,018
    Wow, one of mine was really bent and it didn’t bind, so yours must be pretty bad. They usually bend just below the lower clamp, so short strokes should still be possible.
    It sucks to get old
  10. #40
    camy is offline First Time Rider Arm chair racerNew to the board
    Sep 2008
    Quebec, Canada
    75
    this will be usefull for my 3 200 that need attention!
    Tomy ATC- my mother gave it!!!
    1985 ATC 250SX
    1985 ATC 200X
    1985 ATC 200X
    1985 ATC 200X - Bought from Yamada. Resto mod project
    1985 ATC 70 - Full resto... girlfriend's bike
    1984 ATC 70 - In restoration Lifan 120cc in project
    1983 ATC 70 - Full OEM yard beater!!!!
    1983 ATC 70 - Sold to Yamada who sold it
    1979 ATC 70 - Sold to Yamada
    1973 ATC 70 - 125cc ripper to be bring back to stock
    1985 TRI-ZINGER
    1984 ALT50E
    1983 ALT50D
