some electrical questions
hell, heres the question. my 250R has just had the pulse and lighting coil replaced and i'm still not getting anything from the lighting coil. when installed one end was spliced to the yellow wire and the other was grounded to the mounting lug. i get no resistance with an ohm meter attached. does it make a differance which side of the lighting coil is hooked up to ground? that was going to be my next test but didn't want to take apart the flywheel ect if its not a problem. my other question would be that the headlight was converted to a halogen bulb(like in a fog lamp) and then the tail light was converted to LEDs. I was reading some posts about how the trike ran on AC current instead of DC. will these lights even work?
//ArrowChat Integreation Code
