Are 1985 and 1986 Swing arms the same on Tri-Zs? They look the same but wanted to know for sure.![]()
no and yes, but they will bolt on to either years..
the 86 swing-arm have some reinforcment parts on it...near where the shock link bolt on it...and i think, but i'm not sure...the bearing are different..someone else here on the board can confirm that!!
My rides:
86 YAMAHA TRI-Z
85 HONDA ATC250R
85 swingers run a larger diameter pivot bearing,bushings and seals.Fit that year only...
The 86 swinger runs smaller diameter stuff,and uses the same pivot bearings as banshee and blaster.You can use a banshee pivot bolt in either year of the tri-z.
other than that,and the added gussets on the 86,they are identical.
Proudly NOT a member of
"Team on the Teat"
So a 85 will bolt up to my 86? I just need to order bearing and seals for an 85?
"Team on the Teat"
moshman, Thank you
"Yes!
You will need 2 bearings, 2 inner seals and 2 inner bushings.Expensive from the dealer...
Better yet,Just contact (X system) here on the site.He makes nylon pieces that replace all the factory garbage,and will save you money"
I find a X.system is that the guy?
