Were can I find one new?
Are they interchangeable with any other bike?
the front and rear disc on the 86-87 tecate are the same.
'87 atc200x
'87 kxf250
'87 lt500r
tiger 80
tiger 125
tiger 200
tiger super-4
2 cagiva 200's
4 '85 atc250r
1 '86 atc250r
2 '84 kxt250
2 '85 kxt250
8 '86 kxt250
3 '85 ytz250
'86 ytz250
depends if you want the e brake cable on the 87 like it comes stock. the 84 and 85 rear calipers are different in size. the 84 being smaller then the 85. if you dont want the e brake cable then the 85 model should fit. i know it fits my 86 so i would believe the 87 model is no different where it bolts up. the 87 model is the only year the t3 came with an e brake cable.
84 kxt-A1 rear disc part number: 41080-4001
85 kxt-A2 rear disc part number: 41080-4001
86 kxt-B1 front and rear disc part number: 41080-1162
87 kxt-B2 rear disc part number: 41080-1180
87 kxt-B2 front disc part number: 41080-1162
from the part diagram picture I see that the 84-85 are different than the 86-87
84-85 have offset that the 86 don't have.
Now is the 86 rear disc interchangeable with any newer kawasaki atv rear disc?
The 84-85 brakes have different hole spaces between them. to make them work would take some fabrication. I don't know if the front and rear caliper on the 86 are the same caliper are the same but I do have a caliper from the front of an 86 T3.
I was sitting on it for a rainy day. i can't promise if it needs rebuit or not and i hate to get rid of it but some many people have been good to me around here and i feel the obligation to spread that kindness and help you if you are interested. i'll make you a great deal on it.
Shipping from the US to Greece could get costly though.
Are you looking for the caliper or the disk itself? I have a caliper but not a disk.
Hoosier_Daddy and jeswinehart thank you very much for your interest, much appreciate it.
I'm restoring my 86 tecate and i want to put a new rear disc. ( the old one has been very lean)
I do have the caliper
Thanks again
Finding a front brake rotor (disc) should not be that hard. I have a couple.
How thin (lean) is the one you have?
86 T3
84 T3
86 KX250
oooooooooooooohhhhhhh, i thought you were talking about the calipers, not the discs.
Did you ever find one? I have one for sale.
86 T3
84 T3
86 KX250
Is it new?
no it is used
86 T3
84 T3
86 KX250
