My 200m is very hard on plugs. I have to put in a new one after almost every ride. The engine will still run on the old ones, but will not idle. If I clean and re-gap a plug the engine will then idle on that plug, but not for long. The air filter is good, and the engine only burns a bit of oil on start-up due to bad valve seals. The rings are good so no problem there. What could be wrong?
