Thread: Molds for fiberglass
    Twilight is offline Check my feedback before buying from me Roostin Away
    Nov 2006
    Seattle
    1,552
    Anyone here ever make a mold for a fiberglass part? Any tips? Im going to be able to do some fiberglass parts and want to make a good mold for them.
    gravelyman's Avatar
    gravelyman is offline At The Back Of The Pack Arm chair racerFirst time rider
    May 2008
    richland, mississippi
    219
    use lots of wax paper when applying the resin to the glass so it will not stick to your mold. what are you going to mold? i might could help you a little better i have molded a few parts with fiberglass
    Nov 2006
    Seattle
    1,552
    Ack, I knew I butchered that. I am wondering how to make a mold for something I will be making out of fiberglass.
    Its going to be a roof for the FL350 and FL400 atv's
    gravelyman's Avatar
    May 2008
    219
    first get your design lets say it will be 4x3 square you will want your glass to overlay a lil bit to cut off later build it on a piece of plywood put wax paper down and tack your glass down on top of it apply resin then layer more glass to get the strengh you want. when your ready to make the sides build a box with 2x4's around the top make shure you build it bigger than the top. depending on how you want the sides to look there are several ways to do the next part get some expanding foam put around the inside of the box you made let it expand and dry. make sure none of it gets on any part of what you want to be a final part of your project. when it is dry sand it and shape it. put wax paper on it and apply your glass and resin when done remove your mold and cut off all the excess glass and sand it smooth with a belt sander. also if you have an idea on how you are going to mount it you can install your mounting brackets between several layers of glass
    make sure you reinforce them good luck
