Results 1 to 15 of 19
Thread: How's this piston? (56k BEWARE***)
    Dec 2002
    salem, nh
    1,339
    85 250SX New to me!!
    85 ATC 70 stock ~ TRADED
    85 ATC 70 with 138cc Lifan
    83 110 restored ~ sold
    85 110 restored ~ sold
    83 200x restored ~ sold
    02 400ex ~~~SOLD
    K&N filter
    K&N jet kit
    EHS Racing lid
    Removed choke 42 pilot DJ146 main
    HMF full exhaust
    AC skids
    Holeshot XCR rears
    14t front sprocket
    IMS Roll front bumper
    Graydon Proline nerfs
    Dec 2002
    salem, nh
    1,339
    Cylinder and Head
    02 400ex ~~~SOLD
    K&N filter
    K&N jet kit
    EHS Racing lid
    HMF full exhaust
    AC skids
    Holeshot XCR rears
    14t front sprocket
    Dec 2002
    salem, nh
    1,339
    Exhaust and Rusted Front Sprocket shaft
    02 400ex ~~~SOLD
    K&N filter
    K&N jet kit
    EHS Racing lid
    HMF full exhaust
    AC skids
    Holeshot XCR rears
    14t front sprocket
    Dec 2002
    salem, nh
    1,339
    This is the first motor I've ever worked on. I've done everything other than a motor.
    I'm checking with a micrometer to find out what bore it's at. When I do I will take it to a machine shop to clean up and do whatever is necessary for a rebuild. I was quoted $40 for hone and cleaning, and $20 for a valve job.
    I'm making a list of things I will need for a full rebuild. I'll post the list after some of you make some comments. I obviously need a new piston, rings, gaskets, etc. But do I need new valve seals? And what other things do I need to order from Honda for a rebuild? And what exactly am I supposed to have done at the machine shop. Thanks.
    BTW this bottom end is junk because of that stripped shaft. I bought one off of Coty in place of it...it better work when it gets here!!
    02 400ex ~~~SOLD
    K&N filter
    K&N jet kit
    EHS Racing lid
    HMF full exhaust
    AC skids
    Holeshot XCR rears
    14t front sprocket
    FullBore is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    That all looks ok, it might need a bit of thought on the sprocket shaft, as to if it should have a new one or not but the piston and bore looks good, it looks as though the piston has been a bit hot at some point but it won't hurt it and you can expect that with air cooling anyway.
    Nat
    1979 Suzuki TS100
    1984 ATC70, Broke
    1984 ATC110, Repainted and Rebored.
    1990 Suzuki SJ410
    Unsuspended Antics.
    Quote Originally Posted by kilabeez0
    :shock: :shock: :shock:
    I Wont tell you what I was quoted here in Aussie, but you can nearly times that by 5....
    piston looks like its suffering from detonation, My TZ used to suffer from that BADLY!
    Other thing that can cause it is water.
    Jun 2003
    203
    the piston looks bad but you might be able to salvage it. first thing i wouild do is buy the clymer book. it will tell you where the o rings go. when you put the cylinder and head back on, there are o rings that go on the studs. might as well get the valve seals done since the motor is already apart. at least get it honed and if the cylinder is out of spec, get it bored. then you will have to buy a bigger piston. you might be able to find a good deal for a whole motor on ebay. hope this helps
    later
    if a vegiterian bites their lip, do they feel guilty?
    yep, thats our man. he pulled himself into an airduct. he must have worked out for months!
    84 200x bored 50 over and pipe(more in the works)
    76 ke 175 lookin like a kd 125
    http://mysite.verizon.net/res216cg
    Dec 2002
    salem, nh
    1,339
    I checked the bore with calipers and it's the stock bore. Do I need to take it to the machine shop before I order a piston and have them check the head professionally, or should I just order a standard bore piston?
    Do I need to order anything from Honda to give to the machine shop?
    02 400ex ~~~SOLD
    K&N filter
    K&N jet kit
    EHS Racing lid
    HMF full exhaust
    AC skids
    Holeshot XCR rears
    14t front sprocket
    Ashland City, TN
    2,576
    If the cyl is stock bore, you should just be able to order stock rings and piston and not worry about bringing it to a machine shop except to have it honed. If I was you, I would just buy a honing tool, they only cost 25 bucks for me, and if you bring it to a machine shop, you got your time, gas, and your out 10 bucks. 10 bucks is what my machine shop charges anyways.
    Trikes:
    1973 Honda ATC70-orange!
    (2)1985 ATC70
    1985 Big Red 250
    1985 250R
    Dec 2002
    salem, nh
    1,339
    well i have a friend who can hone it, but i'll still bring the head to have cleaned and the valve seats re-surfaced.
    02 400ex ~~~SOLD
    K&N filter
    K&N jet kit
    EHS Racing lid
    HMF full exhaust
    AC skids
    Holeshot XCR rears
    14t front sprocket
    Stock bore, thats great! That tan discoloration dosen't look like detonation to me but rather oil getting past the oil ring - merely because it was tired. Did you use an inside teloscopic gauge and then a micrometer? You really have to measure it that way and in the 2 ends of the cylinder and the middle. One of the best mechanics I ever met had some long thin feeler gauge stock - he'd just drop one in there and put in the piston and add more until he got a clearance. This of course was a real quick way of checking for overall wear on the bore.
    They need the new piston to bore it correctly if you go with an oversize, but if that stock puppy measures up ok and isn't all scratched up I would just re ring it.
    I don't know what to say about the valves - Honda valves are coated and should never be ground or lapped therefore how do you improve the seat?? I guess they just grind it and that works?? I always thought lapping was the "honing" of the seat to really get it tight but if you can't lap it I guess just replacing the seat is the only way to go. I bet MR ATC could help, throw him a post on the head question, I'd love his input. Good luck!
    Dec 2002
    salem, nh
    1,339
    ^^^Now i'm all confused :?
    So if my engine is covered in carbon and looks like crap, what exactly am I having the machine shop do to it?
    02 400ex ~~~SOLD
    K&N filter
    K&N jet kit
    EHS Racing lid
    HMF full exhaust
    AC skids
    Holeshot XCR rears
    14t front sprocket
    Jun 2003
    203
    have the machine shop check the bore and if it is to spec have them hone it. use a wire brush on the piston to clean it up but dont go nuts. have them also check the valves and have them put new valve seals on. that is what i would have them do
    later
    Clean the top of the piston, NOT THE SIDES with wire brush, get all the crap off it, take another photo and post it.
    closer look at the pics, yea its more carbon than detonation but yea clean it up..
    A hone, just tidys up the bore...
    Dec 2002
    salem, nh
    1,339
    will an anutomotive machine shop have the valve seals, or is that something i need to buy from honda and give to them? thanks for all the help btw.
    02 400ex ~~~SOLD
    K&N filter
    K&N jet kit
    EHS Racing lid
    HMF full exhaust
    AC skids
    Holeshot XCR rears
    14t front sprocket
