Results 1 to 15 of 23
Thread: 85 big red help
    Mar 2008
    Wichita, kansas
    123
    Thumbs down 85 big red help
    i lost spark in my 85 250 big red. its not the plug or coil.......Any ideas?
    My Rides
    1985 350x- Super Trapp Exhaust
    1984 YTM 200
    2005 Trx 450r
    Michigan
    1,144
    Try a new plug.
    85 Big Red
    83 Big Red
    84 125m
    85 TRX 125
    73 ATC 70
    y2kane's Avatar
    y2kane is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Deshler Ohio
    291
    Stator? I replaced mine when it had an orange spark and it fixed the problem.
    1982 Honda 185 My work horse
    1985 Honda 125 kids love it
    1984 Honda 200S My main ride
    May 2008
    Northwestern Ontario, Canada
    552
    How do you know it's not the coil...usually the first thing to go, or the cdi?
    My Trikes...
    -1985 Big Red
    -1986 250r
    -1984 200x
    -1980 110
    -1980 ATC 185
    Mar 2008
    Wichita, kansas
    123
    i took a good coil off another 85 big red that runs and still no spark. its got a new plug. Last night it had spark for a min then quit agian. now i cant get spark at all ?
    My Rides
    1984 YTM 200
    2005 Trx 450r
    y2kane's Avatar
    Deshler Ohio
    291
    I also had a wire that was a ground to the motor on the left side by the pull starter, that had come off and that caused no spark might want to check all wires too. Just a quick thought of my issues I have had.
    Feb 2008
    NE Indiana
    525
    Check your kill switch and make sure it's working properly. If it's corroded or full of mud, it could be malfunctioning.
    smvorndran
    Aug 2007
    Pa
    108
    I had a kill switch wire that was pinched in side the switch that finally wore through. Open it and take a look at the wires.
    Oct 2008
    NB, Canada
    852
    Quote Originally Posted by codemanlyons View Post
    Did you also try the CDI (the little black box on the frame)?
    Mar 2008
    Wichita, kansas
    123
    Yes i also tried the cdi box still no spark...i will look into the kill switch tomorrow
    My Rides
    1984 YTM 200
    2005 Trx 450r
    Mar 2008
    Wichita, kansas
    123
    So i tried the plug the coil the cdi box nothen checked all the wires checked all the fuses took the kill switch off everything is good..still no spark!! what am i missing besides the stator which i want to be the last thing i try???
    My Rides
    1984 YTM 200
    2005 Trx 450r
    May 2008
    552
    Not much left to check after that, more than likely it's grounding out somewhere in the harness...break out the voltmeter!
    My Trikes...
    -1985 Big Red
    -1986 250r
    -1984 200x
    -1980 110
    -1980 ATC 185
    Texas 200x is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Corpus Christi, Tx
    296
    Get a manual and a voltmeter. You can unhook your kill switch so you know it isn't the problem. Check for continuity out of the stator to the engine. Usually that means its good. Clean all your connections and look for any bare wires. Good luck! 100 POSTS!
    Hey, What other dangerously fun vehicles can I Cram in my 2and1/2-car shop? (Garage.)
    gravelyman's Avatar
    gravelyman is offline At The Back Of The Pack Arm chair racerFirst time rider
    May 2008
    richland, mississippi
    219
    have you checked your pickup coil? it sends the signal to the cdi box the cdi box sends it to the coil the coil sends it to the spark plug all the kill switch does is ground it just unplug the ground and that elimnates the kill switch
    Mar 2008
    Wichita, kansas
    123
    i havent checked the pickup coil where is that located?
    My Rides
    1984 YTM 200
    2005 Trx 450r
