Results 16 to 30 of 34
Thread: Almost Went Into Shock!!
    Jan 2005
    RI
    2,530
    through the muffler, head pipe, cylinder, carb, and finally into the airbox
    1986 Tri-z
    1985 250r
    1985 200s
    1985 70[/SIZE]
    edog's Avatar
    Mar 2004
    New Hampshire
    6,629
    They get it threw the scoops on the frames neck.There is a hole behind the small scoop that goes threw the frame tube to the airbox.
    edog's Avatar
    Mar 2004
    New Hampshire
    6,629
    Quote Originally Posted by DeePa View Post
    Thats the long way.
    YOUR DOING IT WRONG
    Hampton, Virginia, C.S.A.
    2,664
    how would they get thrue the valves even if they are open i dont think even a mouse could get thrue
    current rides
    82' ATC110
    85' ATC310R
    85' ATC250R
    85' ATC250ES
    16' brute force 750
    Sep 2007
    100mi west of Chicago
    3,582
    The '84 125m I bought had the airbox full of mouse nest as well as inside the frame. It stunk really bad like mouse pee even after I cleaned it all out.
    Rob
    Jan 2005
    RI
    2,530
    ever hear of a joke?
    1986 Tri-z
    1985 250r
    1985 200s
    1985 70[/SIZE]
    edog's Avatar
    Mar 2004
    New Hampshire
    6,629
    Your humor is dry.
    Internet
    1,251
    I read the thread title and thought for sure it was a play on words and was gunna be about a rear shock or something.
    You shoulda titled the thread 'I almost lost my breath!!' or 'I couldn't breathe!'
    Texas 200x is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Corpus Christi, Tx
    296
    Quote Originally Posted by rdlsz24 View Post
    Rob
    I've never smelled mouse pee before
    Hey, What other dangerously fun vehicles can I Cram in my 2and1/2-car shop? (Garage.)
    Apr 2008
    somerset ma
    1,822
    Between this and your backwards oil filter incident, I think your determined to destroy your poor 350X
    Mice LOVE air filter boxes, I bought a blaster and the crank was filled with debris which of course required splitting the cases
    enough with the backwards oil filter stuff, just think, If I didn't change it before we went on our ride, i wouldn't have a top end right now
    Jan 2005
    RI
    2,530
    good thing you didnt listen to my advice youd be looking at 500 bucks in parts...i always thought the writing on the filters said THIS SIDE TOWARDS SPRING....kidna hard to F up HAHAH
    1986 Tri-z
    1985 250r
    1985 200s
    1985 70[/SIZE]
    Apr 2008
    somerset ma
    1,822
    I swear to god! I thought It was in the right way, live and learn, I guess
    Jackson MI
    1,688
    The filter In the first pic looks like It has no oil on It. You might want to get ya some, because your piston, rings & valve's won't last long like that. It might stop Mickey Mouse from chewing on It also
    83 ATC 70.
    83 Tri zinger
    ATC450AF
    86 310-R Drag racer
    Mar 2007
    FL
    583
    I bought an 85 tecate a couple years ago and while I was test riding it a mouse climbed out of the air box and on to the tank while I was trucking along!!!!!
    82 200e
    85 250es
    86 250r
    Trike fest 08,09,10,11,12,13,15 and counting
    Coal creek 09,10
    Invasion 2011 , Trikes ridden in 13 diff states and counting
  15. #30
    I'll tell ya, my mouse experience was a complete disaster.....
    Went to buy the ex gf a Blaster and he was trying to start it when I pulled in. He said " I haven't run it in a year"
    So, I got a good deal but with all that crap sucked into the crank, I just had to split it. At that time, I had no pullers or oxy/acet etc etc so I brought the bare bones bottom end to my local Yamaha dealer. He charged me over 500$ IN LABOR to split it and replace the mains.......
    When I bitched he said "allot of little parts in that case"..... They actually put the clutch pushrod/bearing together wrong and had to take the clutch apart again - I could have KILLED THEM!!!!!!!!!!!!!!!!!!!!!!!
    If it were a 4 stroke, I would have flushed it, but being a pinger, I had to replace the mains or it would have blown up.
