through the muffler, head pipe, cylinder, carb, and finally into the airbox
1986 Tri-z
1985 250r
1985 200s
1985 70[/SIZE]
They get it threw the scoops on the frames neck.There is a hole behind the small scoop that goes threw the frame tube to the airbox.
My old 1985 250R http://www.flickr.com/photos/24898661@N07/show/
Feedback http://www.3wheelerworldforums.com/s...feed+back+edog
Currently trikeless
Currently trikeless
The '84 125m I bought had the airbox full of mouse nest as well as inside the frame. It stunk really bad like mouse pee even after I cleaned it all out.
Rob
ever hear of a joke?
1986 Tri-z
1985 250r
1985 200s
1985 70[/SIZE]
Currently trikeless
I read the thread title and thought for sure it was a play on words and was gunna be about a rear shock or something.
You shoulda titled the thread 'I almost lost my breath!!' or 'I couldn't breathe!'
My rides, 1985 ATC 350X, With legit Lamborghini Countach paint,2003 Harley Davidson FXDL Dyna Low Rider,customised the way I like it!
1997 GMC Sierra is gone, primary mode of transportation, 2008 Toyota Yaris!
good thing you didnt listen to my advice youd be looking at 500 bucks in parts...i always thought the writing on the filters said THIS SIDE TOWARDS SPRING....kidna hard to F up HAHAH
1986 Tri-z
1985 250r
1985 200s
1985 70[/SIZE]
I swear to god! I thought It was in the right way, live and learn, I guess
The filter In the first pic looks like It has no oil on It. You might want to get ya some, because your piston, rings & valve's won't last long like that. It might stop Mickey Mouse from chewing on It also![]()
83 ATC 70.
83 Tri zinger
ATC450AF
86 310-R Drag racer
I bought an 85 tecate a couple years ago and while I was test riding it a mouse climbed out of the air box and on to the tank while I was trucking along!!!!!
82 200e
85 250es
86 250r
Trike fest 08,09,10,11,12,13,15 and counting
Coal creek 09,10
Invasion 2011 , Trikes ridden in 13 diff states and counting
I'll tell ya, my mouse experience was a complete disaster.....
Went to buy the ex gf a Blaster and he was trying to start it when I pulled in. He said " I haven't run it in a year"
So, I got a good deal but with all that crap sucked into the crank, I just had to split it. At that time, I had no pullers or oxy/acet etc etc so I brought the bare bones bottom end to my local Yamaha dealer. He charged me over 500$ IN LABOR to split it and replace the mains.......
When I bitched he said "allot of little parts in that case"..... They actually put the clutch pushrod/bearing together wrong and had to take the clutch apart again - I could have KILLED THEM!!!!!!!!!!!!!!!!!!!!!!!
If it were a 4 stroke, I would have flushed it, but being a pinger, I had to replace the mains or it would have blown up.
