Results 1 to 15 of 23
Thread: Need help...can't start my 200S.
    Jul 2002
    El Paso, Texas
    512
    I just about pulled my arm out tonight. I rebuilt my 200S a few years ago, but was never able to start it. It sat in storage for a few years. I pulled it out and cleaned out the carb really well. The decompression lever does not make contact with the rocker arm (I have to have it welded on and machined) so I have no decompression. It has a fresh bore and a wiseco 10:1. A K&N and stock exhaust. HELP. I pulled this thing for 2 hours with the choke on, choke off, choke on all the way, 1/4 throttle, 1/2 throttle, and all freakin combinations in between. I need help and some answers to a few questions....
    Because of the high compression is it possible that I can't pull the recoil fast enough?
    Where should my idle screw be set?
    3rd clip on the needle, right?
    Do I need to use a higher octane?
    I have spark (saw it), but could there be something I'm missing electrically?
    Please help me....I'm about to lose my mind and right arm!
    Honda
    86 350X - Full Restomod
    85 250R - Legend
    85 Big Red - Clean Original
    85 Big Red - Custom
    Not Honda
    85 Yam Badger 80 - Kids
    99 Pol Sport 400 - Got it FREE
    Jul 2006
    are you sure you got gas going into the motor? one way to know if you got spark and it wont fire off one or two times with a generous helping of engine starting fluid you probably have some serious timming issues or valve issues.
    Jul 2002
    El Paso, Texas
    512
    I never tried engine starting fluid....does that help a lot? I pulled the plug a few times and found it to be slightly wet with gas....not saturated at all. I suspected that maybe gas may not me making it to the motor.
    Would the timing keep it from starting at all?
    Honda
    85 250R - Legend
    85 Big Red - Custom
    Not Honda
    Jul 2002
    El Paso, Texas
    512
    It's been so long since I timed it.....easiest way to do it?
    Honda
    85 250R - Legend
    85 Big Red - Custom
    Not Honda
    Jul 2006
    almost any motor will run with engine start being sprayed into it.. if not then there are problems afoot! cant help you with the timming on that model..
    Hampton, Virginia, C.S.A.
    2,664
    always make sure the cdi isnt 180 degrees out...i did that once by accident and it drove me crazy
    current rides
    82' ATC110
    85' ATC310R
    85' ATC250R
    85' ATC250ES
    16' brute force 750
    Jul 2002
    El Paso, Texas
    512
    UPDATE:
    No luck yet. I got some Engine Start. I assumed it would be ok to spray it right into the cylinder...so I did. No luck. I checked the CDI for proper connection...good to go. I can't believe this thing won't fire at all. I'm getting spark....I pulled the plug and pulled it over to verify that. I saw the blue arc!
    What do you guys think I should try next?
    Honda
    85 250R - Legend
    85 Big Red - Custom
    Not Honda
    Nov 2005
    southern maine
    99
    no reccomendation for the no start, but if your firing anything with starting fluid, use the stuff with lubricant in it. It means more for a 2 stroke, but it helps to not burn a piston with pure alcohol.
    edit.. sounds like timing to me as well..
    Jul 2002
    El Paso, Texas
    512
    Correct me if I'm wrong, but can't I check the timing by going solely through the CDI cover all the way back to the cam sprocket....making sure all the index marks are aligned correctly. In other words, I don't need to take the head cover off right?
    I swear I did all this when I assembled it.
    Honda
    85 250R - Legend
    85 Big Red - Custom
    Not Honda
    Oct 2008
    NB, Canada
    852
    Is the spark consistent?
    Jul 2002
    El Paso, Texas
    512
    I think so....I'll try again.....but I got a consistent spark when I pulled it about 3 times.
    Honda
    85 250R - Legend
    85 Big Red - Custom
    Not Honda
    Jul 2002
    El Paso, Texas
    512
    The timing was good. ...I drink Bud Light.
    Honda
    85 250R - Legend
    85 Big Red - Custom
    Not Honda
    Oct 2008
    NB, Canada
    852
    Try spraying the starting fluid into the carburetor. Also try to push start it, either from pulling it with somthing, or get someone to push you.
    Jul 2002
    El Paso, Texas
    512
    No luck yet guys... Is there anyway I can test how strong the spark is? Any other suggestions?
    Honda
    85 250R - Legend
    85 Big Red - Custom
    Not Honda
    Oct 2008
    NB, Canada
    852
    If it is getting a blue spark like you say it should start. With starting fluid sprayed into the carborator then quickly after pulled over, without leaveing time to put the air filter back in, it should at least give a kick or pop, if there is a spark. If the timming is far enoough off it may backfire through the exaust or intake
