Thread: transmision or clutch??
    krizo88's Avatar
    krizo88 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2003
    297
    I was out riding my 85 250r last night and every time I would gas on it and shift gears it would slip into nuetral before going into the next gear. But if you dont beat on it, it doesnt do it? Is this a clutch problem or is it the tranny starting to go? All info would be helpful. thanks
    1985 TRI Z
    1985 ATC 250R
    2004 YFZ 450
    Rittman, Ohio
    6,276
    Sounds like clutch is slipping, but either way, youre going to have to take it apart and look, and teh clutch sidecover is a good place to start.
    speed20 is offline Check my feedback before buying from me Arm chair racerJust too addicted
    Jun 2002
    OH-IO
    816
    does that (goes into neutral) when you dont make a perfect shift too!!! when your riding hard (gas, clutch, shifter, gas) you might not be pulling the shifter up far enough!!!
    krizo88's Avatar
    Jun 2003
    297
    nah, i always power shift it with out using the clutch, it keeps the rpms up....... and the front tire
    1985 TRI Z
    1985 ATC 250R
    2004 YFZ 450
