Results 1 to 2 of 2
Thread: ATC 200 - 1981 Transmission Hang up
    Nov 2008
    Fairbanks
    ATC 200 transmission is stuck in neutral. Tips to get it unstuck without tearing the tranny apart?
    runaway is offline At The Back Of The Pack Arm chair racerFirst time rider
    bay city mi.
    154
    hello
    when i got my 185s it was stuck in 3rd gear,after removing the right side of the motor and watching what was going on in there i noticed that the bolt that holds the shift gear to the shift drum had come loose and bent. after replacing that bolt and putting it back together it works fine good luck i hope this helps you.
    if you have a camera take a photo before you disassemble each section. better safe than sorry
