ATC 200 - 1981 Transmission Hang up
ATC 200 transmission is stuck in neutral. Tips to get it unstuck without tearing the tranny apart?
hello
when i got my 185s it was stuck in 3rd gear,after removing the right side of the motor and watching what was going on in there i noticed that the bolt that holds the shift gear to the shift drum had come loose and bent. after replacing that bolt and putting it back together it works fine good luck i hope this helps you.
if you have a camera take a photo before you disassemble each section. better safe than sorry
//ArrowChat Integreation Code
