Results 1 to 7 of 7
Thread: 85 250SX NO SPARK (not NSS)
    Apr 2008
    NJ
    12
    ok well I picked up another 3 wheeler to add to my collection. Its a 1985 250sx. the shifter was kinda hard to shift, was stuck in reverse when I got it. It had no spark since it was stuck in reverse, so I jumped the 2 wires to the nuetral saftey switch and it fired right up. It shifts better now, but not perfect, I still need to pull the left cover and check it out. But anyway its been running great for a few days. I put it away last night and it was running fine. This morning it wouldn't start, no spark. I jumped the wires by the NSS again and still no spark. I have no ignition switch, I have the black and red wires connected. Battery is hooked up but dead ,i just use the kick start. Tried a new plug, also check coil which was good. Not sure how to test the cdi and stator on the 250sx. any help is appreciated, thanks!
    Michigan
    1,144
    There is a fuse back by the battery. It is in a rubber enclosed holder.
    85 Big Red
    83 Big Red
    84 125m
    85 TRX 125
    73 ATC 70
    Apr 2008
    NJ
    12
    forgot to say i already check that and it was OK...
    1985 ATC250R
    1985 ATC350X
    1985 ATC110
    1985 ATC250SX
    1976 ATC90
    1984 ATC200S
    Mar 2008
    Wichita, kansas
    123
    iam not sure on the sx but i know on the big reds you can check the cdi box with a multimeter. you might check into a manuel to see if it shows you how. the pickup coil would also be an option
    My Rides
    1985 350x- Super Trapp Exhaust
    1984 YTM 200
    2005 Trx 450r
    Apr 2008
    NJ
    12
    anyone know how to test the cdi on the 250sx?
    1985 ATC250R
    1985 ATC350X
    1985 ATC110
    1985 ATC250SX
    1976 ATC90
    1984 ATC200S
    Apr 2008
    NJ
    12
    does anyone know what the resistance readings should be? and on which color wires for the cdi and pickup coil?
    thanks!
    1985 ATC250R
    1985 ATC350X
    1985 ATC110
    1985 ATC250SX
    1976 ATC90
    1984 ATC200S
    Apr 2008
    NJ
    12
    figured it out. It was a problem with the shifter. Thanks to this website, i was able to figure it out. The shift drum and shifter stud were both loose, and it was causing the nuetral switch to act up, so it wasn't getting spark. luckily the gasket stayed in one peice and neither bolt was snapped off.
    thanks again for the help!
    1985 ATC250R
    1985 ATC350X
    1985 ATC110
    1985 ATC250SX
    1976 ATC90
    1984 ATC200S
