Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 33
Thread: fox body stang info
    Jul 2006
    Question fox body stang info
    what all needs to change to put the 302 in place of the lx 4 cyl... car is a vert, rear end has been upgraded to the 8.8 new tubular control arms and trailing arms and gt brakes allready installed.
    302 is same year motor with harness and ecm trans etc etc...
    so... 302 mounts and plug in the correct ecm? I heard its pretty strait forward swap
    also I dont have any exhuast where are the o2 sensers? are they in the manifolds? becouse if they are I can just make my own exhuast (no inspections here)
    not going to be a drag car... possibly lowerd and firmed up to make a good street curvy carver
    any other sugestions?
    Dec 2002
    Spruce Pine, Alabama
    1,263
    The O-2 sensors go in the exhaust pipe after(just downstream of) the headers.
    '84 ATC70.....my 8-y.o. son's ride
    Jul 2006
    before all the cats?
    Apr 2006
    Crestview, Florida
    2,429
    From what i've read and heard you have to change the k-member. Let me know how it goes, i've got a 93 lx im gonna start on in a few weeks if i can find a cheap engine/trans.
    Rides
    85 ATC350X
    85 ATC200X
    Dec 2002
    1,263
    Yep.
    They go between the header/manifold-to-exhaust pipe hookup and the 1st cats in a 4-cat H-pipe system on the '86-'93 models.
    PA
    3,515
    Quote Originally Posted by DixiePlowboy View Post
    Yep.
    thats the same as 94-95 too
    if you want some sites try allfordmustangs.com and corral.net
    WWW.HREATV.COM
    topless is offline At The Back Of The Pack Arm chair racerFirst time rider
    Dec 2007
    Kansas
    160
    You don't need to change the k-member, just the motor mounts. If you want dual exhaust, you'll need a double hump transmission cross-member.
    Do yourself a favor and run shorty headers, long tubes and equal length shorties are a real pain when you go to work on anything, starting with just dropping the motor in. Shorties you can bolt on before, the others you have to install after you drop in the motor. On a 400 hp motor shorties might cost you 5-10 hp, but you won't care after you bust up your knuckles and lose 2-3 hours. The O2 sensors go in the H pipe, (I'd run an off-road X pipe) they come with the bungs installed. If you make your own, look at what's sold by FMS, Steeda, MAC..etc. to see how to make it.
    Dec 2006
    St. John's Newfoundland
    1,587
    Ya the 4 cylinder k member will work. The V6 model doesnt. I would suggest subframe connectors too. Easy mod and stiffens the body up so it don't twist. Also the fuel pump may not be enough so we use to take VW external pumps cant remember which ones and they looked almost like a t-rex pump and are roughly the same psi.
    1986 ATC 250r
    1985 ATC 250r
    1985 X2 ATC 70's
    1985 XL 80
    I know that 8 bolts hold that whole front end on - easy to swap to a 5.0.....
    And the rear suspension stuff fits oh just fine too.....
    I only know because - well, I, uhmm, kinda, took, sorta, got involved, sorta related to, err - I better just STFU right now!!......
    They sure do strip down quick though! Esp the ones that come right off the dealers lot! Woo Hoo leather!! Woo Hoo sweet rims!! Woo Hoo Saleen
    Sorry about the useless information
    Nov 2004
    Waterloo IL
    2,701
    Quote Originally Posted by topless View Post
    I agree with all this but in my opinion long tubes are worth it. They aren't bad to get in at all with a 302 especially with the engine out and a tubular K-frame. Also the O2 sensors will screw into the long tube headers instead of the H-pipe. I'd just buy all the exhaust either way, H-pipes are cheap. I have dual 3-inch exhaust with long tubes on my 92. The H-pipe is a lot easier to bolt to long tubes than it is shorties too since the H-pipe starts under the car with nothing else around instead of way up by the engine like with shorties. I've done tons of long tubes, peice of cake on a 302, try that on a 4.6 and let me know what you think. A lot of people will drop the K-fram for that.
    And on a side note a V8, V6 and 4 cylinders all the the same K-frame, the straight 6 is the odd ball.
    08 Outlaw 525s
    07 CRF70
    04 Harley FLHRCI
    04 TRX90
    03 XR650R
    03 400EX- XR650R engine
    02 XR100R
    01 Banshee
    00 XR50R
    00 XR70R
    99 PW50
    99 JR50
    96,95 Sportsman 400
    95 Xplorer 400
    94 Indy XLT
    87 Trail Boss
    86,86,86,86,86 Scrambler
    86 TRX70 x2
    85 ATC350X
    85,84 ATC250R
    85 Red Tecate
    85 LT50 x2
    84 XR500R
    84,84,84,84,83,82,80,79 ATC70
    82,79 XL500R
    83 ALT50
    79,78,77,77,76 XT/TT500
    76,75,74 XL70
    72,71,71,71 SL70
    72 Harley FX
    72,71,70,70,70,70,70 CT70H
    72 SL100
    70,69 Z50
    Jul 2006
    SO what about the harness.. I was told that the stock 302 engine harness wil plug into the LX harnes and you just plug the 302 ecm into it and take the old 4cyl ecm out.. is this correct?
    Nov 2004
    Waterloo IL
    2,701
    Pretty much yeah. Swap ECMs. If you look in the center of the engine bay up against the firewall there are too larger electrical plugs. Those plugs feed the entire engine harness. Remove the 4 cylinder harness and plug in the 5.0 harness.
    08 Outlaw 525s
    07 CRF70
    04 Harley FLHRCI
    04 TRX90
    03 XR650R
    02 XR100R
    01 Banshee
    00 XR50R
    00 XR70R
    99 PW50
    99 JR50
    96,95 Sportsman 400
    95 Xplorer 400
    94 Indy XLT
    87 Trail Boss
    86 TRX70 x2
    85 ATC350X
    85,84 ATC250R
    85 Red Tecate
    85 LT50 x2
    84 XR500R
    82,79 XL500R
    83 ALT50
    76,75,74 XL70
    72,71,71,71 SL70
    72 Harley FX
    72 SL100
    70,69 Z50
    Jul 2006
    THATS what I wanted to know!!
    the exhuast thing is just going to be temp untill I put a good stainless one under it.. this car wont be mine though
    dont have big plans.. mainly make is a really nice street car no draggin or anything like that.
    Jul 2006
    does anyone have one of the V8 trans cross member so I can run the pipes?
    Apr 2004
    Brigham, Québec, Canada
    1,528
    Quote Originally Posted by Blown 331 View Post
    BBK Shorties on a 4.6 sucks. We did it to my cousin 96 mustang and it was a real pain to do. After they were all bolted up they hitted the steering shaft. Stay away from BBK headers.
    1984 Yamaha YTM-225DX
    Québec 3-wheeler riders group
