Results 1 to 8 of 8
Thread: 250R clutch issues: Funky noises when engaging clutch
    STL
    3,560
    Since I bought the bike 3 years ago it makes a funky 'creaking' noise when the clutch lever is let out just about to the point of engagement. It actually makes letting the clutch lever out in 1st gear a little tricky.
    1upfront rode the bike down the drag strip at trikefest 08 and might have some contribution about whats wrong with the clutch. Im pretty much lost
    I dont like the noise and need to remedy it. I have the clutch cover off right now and am about to pull the disks and basket out to take a look at what might be the issue.
    I need to get this straightened out fast for the Glamis trip that is quickly comin up. the bike is an 83 sprock big bore 300 but Im selling the cylinder so I can use a honda line 300 cylinder/head since Im sick of trying to deal with the 3 helicoiled studs on this cylinder
    on that note, if anyone wants to buy a 300cc cylinder and head let me know. I can include the wiseco piston which has 20 minutes of ride time on it this is the same engine I had at trikefest, but it has been bored over since then due to me burning the rings up on the last piston.
    Apr 2007
    I remember the noise but am not sure whats causing it have you checked for debris in your tranny oil? Also have you pulled the clutch cover and opened up the clutch to check for anything unusual? let me know and we can narrow this problem down.
    Airfoolers RULE!!!
    STL
    3,560
    I drained the tanny oil earlier and it was clean. Headed out to the shop to pull the clutch out, Im at the sprock farm and his shop is FREEZING!!!!!! will report back with info
    Apr 2007
    Alright man let me know if you see anything odd. Also inspect the throwout rod and ball while it's apart. While your throwout rod is out pull that little screw below your clutch arm on the opposite side of the motor and pull the arm up out and inspect the cam on it.
    Airfoolers RULE!!!
    Apr 2007
    Is your clutch cable in good shape?
    Airfoolers RULE!!!
    Jackson MI
    1,688
    Tell Corey to get the corn burner going
    83 ATC 70.
    83 Tri zinger
    ATC450AF
    86 310-R Drag racer
    STL
    3,560
    Quote Originally Posted by 1upfront View Post
    the ball is in good shape! the clutch basket has some groves in it though but they arent that bad. I have seen some tri-z baskets that looked worse lol the clutch cable should be fine
    Quote Originally Posted by Jason Hall View Post
    I tried that corn burner thing and now it burns whens I pee
    Apr 2007
    Is there any damage to the rod or clutch arm cam? If these are fine I would check and see if your clutch steels and friction disks are in spec and have no warpage and replace if warped or worn.
    Airfoolers RULE!!!
