Thread: Tri-Z killing Spark Plugs
    Nova Scotia, Canada
    7
    Hey guys ,, what would cause my Tri-Z to kill spark plugs alot,,, sometimes i will go thru 2 plugs a day ,,, other times i will get weeks on a plug,,,
    1986 Tri-Z
    DG Pipe
    Uni Air filter
    Columbia
    5,131
    What do you mean kill? Foul?
    How do the plugs look when you pull them? Black and wet?
    Id Say your to rich. Hows the throttle response? Does it hesitate on bottom? Top?
    Dec 2002
    Spruce Pine, Alabama
    1,263
    I may be oversimplifying this, but noticing your earlier jetting issue thread, I'm assuming that you've got a fresh/clean air filter in it.
    If you've started from factory jetting specs, taken plug readings on every change, re-jetted to compensate for what the plugs are telling you, and still losing plugs and having power issues, that maybe something else is working against you.
    You're not mysteriously losing transmission oil are you?
    '84 ATC70.....my 8-y.o. son's ride
    Nova Scotia, Canada
    7
    hey ,, ya im running BR8ES plugs ,, ,, & for jetting i started with a 320 jet and it bogged @ wot ,, then tried a 420 ,, same thing ,, cutting out and bogging @ wot,, so i dropped down to a 220 main jet and it worked fine ,, well i checked the plug ever now and than and its a Light brown,, which i thought was good,, But today when i took the plug out it was light blackish color and wet,,,,,,,,
    1986 Tri-Z
    DG Pipe
    Uni Air filter
    Nova Scotia, Canada
    7
    & ohh no it never went down a bit in tranny oil ,,, when i put a new plug in it ,, it works good,, pulls hard thru fr idle to wot !!!,,, ,, no hesitation ,,, maybe i have to drop down to an even smaller Main jet ????
    1986 Tri-Z
    DG Pipe
    Uni Air filter
    Aug 2006
    Arlington, Wa
    1,027
    sounds like you need to work on the needle and pilot jets. Most folks ride on the needle and not the main. Only you know that answer, and if you don't jet for how you ride, problems will still arise.
    Charlie Don't Trike
    85' ATC 350X
    85' ATC 250SX
    85' YTM 225DX (sweetie)
    84' ATC 200 auto X
    85' ATC 70
    85' YT 60
    My Partz Auctions
