Hi,
I won a older 3+3 durablue axle off of e-bay. It came off of a 1985 200X. When I got it, it was apparent that it was on a 200X but not the correct axle for the 200X. It had a crappy spacer on it to move the disk hub in further but it still runs out of spline before it seats tight to the axle bearing so they must have been running it with a good amount of side to side play( about 1/4"). I can easily fix that problem with some minor machine work but my main problem is finding a rear sprocket for it. I'm sure the axle is for a honda, possibly an 83-84 250r. The sprocket hub is factory welded to the axle, It has 4 sprocket mounting holes. The sprocket mounting holes (across from each other) are approximately 4 1/8" center to center. Can anyone tell me if this is a 83-84 250r axle, what sprocket would fit it, or what machine this axle could be for? An answer to any one of these questions would be very helpful. Thanks in advance.
Xfile
