Results 1 to 15 of 27
Thread: 1986 Tecate rear tires?
    oOGoFastOo's Avatar
    oOGoFastOo is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2007
    Oregon
    265
    I was looking to get new rear tires for my 86 Tecate, and like the Titan Fast Trekkers but i dont know weither to go with 18x11x10 rears or 20x10x10. I found both sizes on ebay for cheap but they are factory blems. what do you guys think??
    Attached Thumbnails Attached Thumbnails Tecate Done 1.JPG   Tecate Done 2.JPG   a titan.jpg
    Oct 2007
    Grosse Tete, LA
    3,440
    do a search I remember a thread for a company selling non blems for a good price.
    what kind of riding do you do? terrainwise?
    oOGoFastOo's Avatar
    Nov 2007
    Oregon
    265
    When I'm not riding in the dunes, I ride mostly in our farms grass fields or on gravel or dirt roads around my house.
    Nov 2006
    southern oregon
    2,338
    Quote Originally Posted by oOGoFastOo View Post
    I would go with 18's....
    Sinbad46's Avatar
    Sinbad46 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2007
    Canada, Québec
    232
    i have 18x11x8 on my Z "BLEM FAST TREKKER" and 18x11x10 on my 250R, and they are really good on gravel or dirt road!
    My rides:
    86 YAMAHA TRI-Z
    85 HONDA ATC250R
    I've never ridden in Oregon, but if it's rocky like it is here, I'd stick with the 20's.
    I've got the blemished 18" Titan Fast Trekkers from Ebay. Super cheap but awesome tire. I can't even find a blemish on mine. However, the 18's aren't any good around here in the woods, in the mud, or on the hills. I rode with my 18's once and immediately put my 20" Razr's on. The 18's are perfect for motocross because they corner well, but they just won't push you through the mud, not to mention the lack of ground clearance is going to bash up your chain and brake rotor if it's rocky there. You'll also have to change your gearing with the 18's. I will always have the 18's on hand for MX, but that's it.
    The 20's give good ground clearance and are just slightly worse in the mud than my stock 22's, but they corner decent and look good. You probly won't have to change your gearing with them, either.
    For everyday riding I would reccomend the 20's for sure.
    Here are the 18's-
    Here are the 20's-
    oOGoFastOo's Avatar
    Nov 2007
    Oregon
    265
    Does any one have any pictures of a 86 Tecate with 18's and 20's on it? I don't know if the 18's will look too small with the extended swing arm on my bike.
    Oct 2005
    saratoga, ny
    2,819
    my 86 with 18 inch fast trekkers... i love this look!!!
    and yes, before the questions fly...that is my 85' rear bearing carrier, axle, and hubs on my 86. i just had to see what it would look like with the fatass and 18inchers on it.
    Sep 2005
    MICHIGAN
    2,027
    Here's mine with 18s. I think they are too low for riding conditions around my state. I only used them once and now they are sitting around doing nothing. I did not like how there was a bit of a gap between the rim and the tire. No one else's pictures look that bad. Mine were blems and all they had wrong was like a thin fin all the way around on the tread. Came right off with a razor blade. Maybe I should make them into ice tires since it is kinda hard to sell them with those blowout tire deals on ebay.
    86 T3
    84 T3
    86 KX250
    oOGoFastOo's Avatar
    Nov 2007
    Oregon
    265
    Thanks guys, Scooterroo are those flames painted on to the rear swingarm? Is there any pictures of a set of 20's on a Tecate or another trike with 10in wheels?
    My second pic is my Tecate with 10" wheels and 20's.
    oOGoFastOo's Avatar
    Nov 2007
    Oregon
    265
    I went with the 20x10x10 for $20 each. I'm hoping they will come by this weekend, I'll post some pics when I get them put on.
    Newfoundland
    5,280
    Heres something to mull over in your head. Honda 250X or 300EX hubs that have worn splines inside and fit sloppy on the Honda axle would fit tight on the 86 Tecate axle so you can run the wide selection of Honda wheels. There are always lots of Honda 450R wheels on ebay that are new takeoffs. Not to mention the wide selection of tires for 9 inch rims.
    Anyway...if you want to trail ride or ride anywhere that isn't perfectly flat and groomed then I'd go 20 inch. 20 inch Turf Tamers would be great.
    Opps, passed that last comment and posted.
    oOGoFastOo's Avatar
    Nov 2007
    Oregon
    265
    I run banshee hubs so i can run 8inch wheels with my paddles so if i wanted to buy wheels i could get alot of options. but thanks for the info
    oOGoFastOo's Avatar
    Nov 2007
    Oregon
    265
    here is a pic of it with them.
