Thread: Tri-z Fuel Pump Rebuild
    May 2008
    Tenn
    548
    The fuel pump on my 85 Tri-z has a small leak in the tube to the cylinder so I bought a rebuild kit. There's nothing in the repair manual about it but upon disassembly it seems to be fairly easily to rebuild. What part actually goes out on the pump and causes the back leakage and is there any important notes about the repair I should be aware of.
    Thanks
    Just-Tri-It
    :Trikes Owned:
    1985 Tri-z's 3
    1986 Tri-z
    1984 YTM 200ERN 1
    na
    5,702
    It is a simple repair, cut and dry.For some reason, They mounted that outside plate in the wrong area,so the words were crooked.I dont know why they did that.
    So I just index the cover to the correct posistion,when I do them.It would also be a good time to pull the little petcock bowl off and reseal it.I also use teflon tape on those threads for extra insurance.
    Probably,there is a pinhole in one of the plastic membranes that was allowing fuel to get in that line.
    Proudly NOT a member of
    "Team on the Teat"
    Danold's Avatar
    Danold is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2007
    barnesville, Ohio
    193
    Sorry to dig up an old thread but, I tore my tri-z fuel apart and found that the vaccum side diaphram has a hole in it. I looked at oem parts websites and all they had was the hole pump assembly( which most likely not availible). Is there anywhere I can buy a rebuild kit or just the one diaphram?
    85 200x
    85 Tri-z
    86 Bigred
    81 Rm60
    John Deere racing tractor
    Quote Originally Posted by wad
    sorry dude mine are all shitters lol
    Sep 2006
    Northwest Indiana
    1,893
    oem# 38w-w1391-01-00
    This is factory pump rebuild kit availiable through any Yamaha dealer. I just ordered 2 in April just to have on hand.
    Danold's Avatar
    Nov 2007
    barnesville, Ohio
    193
    Thank you very much. How much did it cost? I will go order one ASAP.
    85 200x
    85 Tri-z
    86 Bigred
    81 Rm60
