Results 1 to 14 of 14
Thread: help my 185s has got no spark!!!
    runaway is offline At The Back Of The Pack Arm chair racerFirst time rider
    bay city mi.
    154
    hello
    i went to start my three wheeler today and there is no spark i tried a new plug and still nothing. does any one know the test numbers for the coil,cdi and magneto? any help will be appreciated.
    Jul 2004
    Pride, Louisiana
    286
    Had a similar problem with my 185S. I trimmed the ends of the plug wire, checked all the wiring and found out it is a bad kill switch.
    1977 ATC 90
    1983 ATC200E Big Red
    1985 Heald Super Bronc VT-10
    1999 Bayou 220
    2007 Polaris Outlaw 90
    bay city mi.
    154
    hello
    i already did that. still no spark.
    louisiana
    1,499
    Cdi
    Probably Your Cdi
    bay city mi.
    154
    hello
    how do i test the cdi?
    Jul 2004
    Pride, Louisiana
    286
    I wish I had a scanner. I have a trouble shooting and value table for the CDI , coil, pulse generator, and A.C. generator.
    AC generator Lighting coil is good if there is continuity between the white/yellow wire and ground.
    AC generator Exciter coil is good if there is continuity between the black/red wire and ground.
    Primary coil resistance (tab to ground lug on coil)= 0.2-0.8ohm
    Secondary coil ( Plug Wire to ground lug) resistance=8-15k-ohm
    1977 ATC 90
    1999 Bayou 220
    bay city mi.
    154
    hello
    thanks so much! so on my ohm meter i put my black wire on the body of coil and the red in the plug wire?
    Jul 2004
    Pride, Louisiana
    286
    The CDI is fully transisterized. My meter won't read my module (black box) correctly.
    1977 ATC 90
    1999 Bayou 220
    louisiana
    1,499
    Cdi
    If You Have Any More Running Atcs Just Put The Cdi Off The Non Running Bike On A Running One,try To Start It Up,if It Doesnt Start Theres Your Problem,thats What I Always Do.
    Jul 2004
    Pride, Louisiana
    286
    For the Primary test, test from the male wire plug and the closest mounting tab.
    For the secondary test, test the other mounting tab to the end of the plug wire (with spark plug cap removed).
    The plug cap has a resistor in it, but the book doesn't provide values for it either.
    1977 ATC 90
    1999 Bayou 220
    bay city mi.
    154
    hello
    i have only the one trike i belive its my coil i get nothing thru the plug wire.its dead.any one wanna trade a atc 70 air box with the boots for a coil?
    Mar 2007
    Texas
    5,045
    someone on here woudkl probelby give you one. they can also be had off ebay for not too much either. i do't knwo if any of the others off the parts bikes are workign units, so i'd rather not send them off incase they re bad.
    ________________
    https://www.mikesatvfix.com
    bay city mi.
    154
    hello
    thanks for the offer. you know thats what makes this site great, the people on this site are just awesome.
    Howdy's Avatar
    Celina, Ohio
    10,079
    runaway, have you checked the stator to see if it is good? They are known to go bad in this style motor and there is a realitively cheap and easy fix. Here is a thread that may help: http://www.3wheelerworldforums.com/s...oil#post465181
    Howdy
