Thread: help with carb rebuild
    Nov 2008
    maine
    55
    i tried to clean my yamaha 225 dx carb.
    i took everyting apart, and sprayed PB blast through all passages.
    and i used it to clean the jets, needles ect.
    i know that the float and needle work because when i turn the fuel one i can see that gas goes through the hose and fills up the bowl.
    YET...i still get NO gas into the cylinder!
    spraying starting fluid into the carb i get it to fire some, but i cant seem to get gas though the carb!
    any ideas on what im doing wrong???
    Sep 2007
    100mi west of Chicago
    3,582
    You unscrewed the jets and can see daylight through them?
    Rob
    Nov 2008
    maine
    55
    is the jet the screw that is on the underside of the carb, near where the carb attatches to the intake to the motor?
    Nov 2008
    maine
    55
    also, when it comes to cleaning carbs, if read that some let them soak. soak in what?
    it may be that i havent cleaned my carb good enough. looking for another way to go about it.
    Sep 2007
    3,582
    Jets are on the very bottom, once you remove the bowl. The screw that you are seeing is the a/f screw.
    I will usually spray some GumOut in a little container and then soak the jets in there.
    Rob
