Results 1 to 2 of 2
Thread: Noob with '85 ATC 110 and a few questions
    Nov 2008
    State Capitol Raceway, Louisiana
    3
    I just bought my first powered bike. It's pretty much all there, just in need of some TLC. It starts, runs, and shifts through all 4 gears, high and low, but there seems to be some carburetion problems. I have to give it throttle and/or choke it off and on to keep it idling. The bearings in the rear are beyond shot and the brakes are non-existent. I've rebuilt a few go-carts with Briggs and Stratton 5hp engines, but never messed with this sort of thing. I'm sure the carb just needs a good cleaning or refreshing. As for the rear, I can rebuild it with new seals and bearings. The brake drum has a few dents in it, probably why the shoes were removed. On eBay, I found an axle from a 125 complete from wheel nut to wheel nut that looks identical to my stuff- will it interchange? The same seller also has a 125 motor- will that be a direct swap-in? My 110 runs, but seems to take a second to rev and sounds like its really struggling towards the top end. I don't know if it's from bad carburetion, weak motor, worn valvetrain, or what. I figure it would be worth the money for the extra power. Speaking of, what are the power figures for the 110 and the 125? I don't wanna dump thousands into this bike on a restoration. I got it for $120 and am looking for a fun, reliable yard bike that can maybe get the front wheel up.
    Anyway, I'm enjoying my new project so far and look forward to making some new friends here.
    Oct 2008
    Angleton, TX
    44
    You'll spend 60 bucks with the brakes, seals, and bearings. Clean the carb good and that will take care of the rev problem at the top end. I had an 83 110 and it was fun. It would go through anything. Have fun with it. I had fun with mine and I regret selling it.
    I've had:
    '85 ATC 125M
    '83 ATC 110
    Now:
    '84 200ES BIG RED
