Results 1 to 11 of 11
Thread: TriZ parts availability
    Oct 2007
    Grosse Tete, LA
    3,440
    I'm rather curious as to what's still out there for the Zs.
    I know thanks to a few members, plastics are fairly easy to come by. But what about bearings, do the Banshee rear ends swap.
    What's all out there? Sprock has the coolheads and big bore kits, but are cylinders themselves still fairly easy to find?
    Can the stock fuel pump keep up with the 330? can fuel pumps still be found new?
    What about radiators? any options?
    What's the major issues with the bikes? Picking up a new project in a while.
    Aug 2005
    Lockport, NY
    2,395
    Goat just about everything is out there.
    Sprock has :
    full plastic sets
    coolheads
    bigbore kits
    beefy base gaskets
    hi-flow waterpumps
    quickchange clutch covers
    extended swingarms are in the works
    As well as SEVERAL other things
    Hagen - Greenboy has -
    stator covers
    footpegs
    tail light brackets
    Shawn - Sblt500r has -
    billet shifters
    boost bottles
    radiator gaurds
    rear fender mounts
    chain guards
    motor mounts
    AllBalls has all the bearing kits you need. Which you can get from member DADS.
    I am currently working on oversized radiators. But that wont happen until after JAN 1.
    The stock fuel pump works perfectly.
    Clutch covers are prone to cracking. But thats because most guys can't start there bike properly.
    Waterpumps are prone to failing. But if properly pinned they will work perfect. You can even upgrade to sprocks hi-flow pump.
    Ronnie - Yamahondaman used to have alot of stuff. But I don't believe he will be messing with it anymore. You may have to contact sprock for all his stainless goodies.
    Oct 2007
    Grosse Tete, LA
    3,440
    what's the power output of a 330z?
    also...pipes? anyone still making anything good?
    Aug 2005
    Lockport, NY
    2,395
    Power looks mighty impressive if you have seen moshmans 310 in action against many sport quads and shee's it lays a nice whoopin on many in the drags.
    As far as pipes. DG's are most common. There are a few rarities rolling around LRD, Trinity, Bassani, Cobra, etc. JEMCO is building sectionals still for both stock and bigbore motors.
    I want to have Rich at Dynoport build me a sectional for my bigbore.
    Oct 2007
    Grosse Tete, LA
    3,440
    I do like the jemco...it would be pretty in chrome
    Aug 2005
    Lockport, NY
    2,395
    p weasel here on the boards had a bigbore jemco pipe built. I haven't heard anything after he posted it.
    Believe me, between what Jeff and Mike are able to come up with, I really wish I had a Z and was a Tri-Z fan......
    The stuff Sprock is making and what Ronnie is capable of is simply amazing.
    We need a Honda guy to get things rolling on red
    Columbia
    5,131
    I do like your tachs John.
    As far as parts go, used parts are fairly cheap, and availible.
    The banshee rearend:
    The axle is a direct bolt from a Banshee, or a Blaster
    The sprocket hubs are a direct bolt up to the Z
    The wheel hubs from a Z are the same as a Blaster, but not the Banshee.
    And here's a thread that may help:
    http://www.3wheelerworldforums.com/s...i-z+swap+parts
    They are very comfy great bikes. get it, build it, enjoy!
    Apr 2004
    Brigham, Québec, Canada
    1,528
    Quote Originally Posted by The Goat View Post
    A little off-topic but any idea on the color scheme for this new «project»...?
    1984 Yamaha YTM-225DX
    Québec 3-wheeler riders group
    Oct 2007
    Grosse Tete, LA
    3,440
    the new color scheme will either be black, machined, and orange plastics....
    or
    total sleeper except for the pipe.
    It will likely be the first option.
    but seeing as how this is a couple of grand...it's gonna be at least 6 months before I start assembly.
    My goal is to finish the 350x before summer...COMPLETELY. it'll be a year and a half build, but worth it in the end.
    Jan 2005
    Columbus, Georgia-Mid Dixie
    5,301
    And where is this project Z coming from????
    The Z's are very easy to get parts for. A lot of newer stuf bolts right on. Gone are the days of needing a big budget to biuld a good Z. Depending on what you want out of it and what you want to spend you can do anything with them.
    85 Tri-Z's
    85 Quad-Z,
    85 YT175 For sale,
    83 YTM 225DX,
    83 YTM 200L For sale,
    82 Tri-Zinger 60 For sale,
    8? YTZ 80 Conversion,
    85 YT 125,
    89 Pro Hauler 230,
    05 YFZ 450,
    99 V-Star,
