Need carb help
Ok here goes. 4-stroke carb tuning. Starting with completely rebuilt motor. It has been run aprox 2 hrs to break in. It will crank fine, it will run at idle, it will not take the fuel if you get on the throttle fast, it will take fuel if you throttle up slowly, but it pops fire out of the exhaust. It will not run well enough to do a high speed plug check. This is what I have done, drained, cleaned and dried tank, it has fresh gas. Dropped main jet sizes and it helped some. It is at stock main now. The needle is some type of aftermarket so it only has one clip grove. The bike suposedly ran fine before the rod broke. But it will not run right after the rebuild. What do I need to adjust and which way lean or rich? I know this is very general, just looking for basic carb theory.
Thanks
Trikes: Cagiva 200, 85? Tiger 250,(2)84 200x's , (3)86 200x's, 87 200x, (5)85 350x's, (2)86 350x's, (2)85 250r's, 86 Tecate, (3) 85 250sx's Restoring: 83 200x, 86 250sx. Too many utility trikes to list.
