Results 1 to 14 of 14
Thread: 85 350x rear brake hub
    Nov 2008
    Warrenton Va
    5
    I have a 1985 350X and have been at this awhile and can't find a solution. Any info is helpful. Thanks.
    The carrier bearings died. Ordered a RAD twin row carrier for 85 350X. Went to reassemble and the brake hub side carrier seal is not the same size as the brake hub itself. The hub itself is necked down where the seal would ride. There seems to be about a 1/4 inch difference between the hub and the seal diameters.
    The old carrier seal for the brake side had the same size difference. The previous owner must not have cared but I do.
    I assumed it was the wrong seals from RAD so I got stock seals from the local dealer and they are the same that came in the RAD carrier. So the problem looks to be that the brake hub is necked down too far to fit the seals. It fits the axle splines so it must be something of the same bloodline but it is different.
    Did an 86 350x have a smaller diameter mating surface for the brake hub/carrier seal interface?
    Is there an aftermarket 85 brake hub I may purchase?
    I have a mill and can cut down the seal seat but cannot mill it's diameter down. I have heard that a 250r hub can be cut down. Is that true?
    If you have any thoughts please post. I gotta fix my toy so I can get my fix...
    PA
    3,515
    no...your hub is worn
    the rubber seal eats a grove in the hub. you could have it welded up and turned back down on a lathe
    WWW.HREATV.COM
    Nov 2008
    Warrenton Va
    5
    Thanks Swigin. It is way beyond worn from the rubber though. There really is nearly a 1/4 inch gap in there. Those two parts were never meant to be used together. It is like the carrier is from another machine.
    Problems:
    2007 Raptor 700 chip, intake, exh.
    2003 Polaris 700
    1985 ATC 350X ported, polished, intake, exh.
    1985 Odyssey FL350
    1989 Jeep Mangler, 350hp mouse, 42 in Swampers
    1999 Dodge Ram Cummins, 600HP and 37 inch tires
    NEVER ENOUGH!!!!
    PA
    3,515
    pics?
    any other hub that i know will fit uses that same seal
    WWW.HREATV.COM
    Jun 2003
    englishtown NJ
    2,676
    the liquid 250r hub fits, its needs to be cut down and Also you need to use the 250r brake stay, rotor and caliper. Mr. Atc had a thread about this on 3wheeler.org.
    PA
    3,515
    Quote Originally Posted by deathman53 View Post
    right, and so will 250x/300ex and 450r but they all use the same seal.
    WWW.HREATV.COM
    Nov 2008
    Warrenton Va
    5
    I will get a pic and post it. The hub is just necked down where the seal would ride.
    What is the difference between the 85 and 86 rear? RAD lists two different model carrier for the 350x and I am just curious why?
    Problems:
    2003 Polaris 700
    1985 Odyssey FL350
    NEVER ENOUGH!!!!
    Jan 2005
    RI
    2,530
    it has to do with the way the sprocket mounts up to the hub, you can use an 86 carrier in the 85 swinger, but you need an 86 sprocket and bolts to attach that sprocket to the hub...
    1986 Tri-z
    1985 250r
    1985 200s
    1985 70[/SIZE]
    Apr 2004
    Brigham, Québec, Canada
    1,529
    Maybe you could take the bearing carrier and hub to a local store that sell bearings. I'm sure they could measure it for you and find the right seal. And it won't cost you more than $20
    1984 Yamaha YTM-225DX
    Québec 3-wheeler riders group
    Minnesota
    784
    Its my belief that the seal mating surfaces on the disk hub and sprocket hub are just thin sleeves pressed onto the hubs. I didn't figure this out till I looked at a worn one I had real close and tried tapping it off and it split. Its very similar to a repair sleeve for a harmonic balancer on a motor. So maybe your missing the sleeve? I don't belive you can buy just the sleeve from honda, but maybe one could be made.
    PA
    3,515
    Quote Originally Posted by hrc200x View Post
    i was thinking the same thing ...lol
    WWW.HREATV.COM
    Nov 2008
    Warrenton Va
    5
    If it is a sleeve I may be able to butcher a used 300ex carrier and just mill down the sleeve. Freeze the carrier, blast the sleeve with a torch and knock it off then swap it to my 85 350x carrier. Thanks for the info.
    Problems:
    2003 Polaris 700
    1985 Odyssey FL350
    NEVER ENOUGH!!!!
    Hampton, Virginia, C.S.A.
    2,664
    Quote Originally Posted by DeePa View Post
    yes the difference is the 86 sprocket and bolts are countersunk...and rads 86 carrier sticks out so far it will hit the bolts for the 85 sprocket bolts
    current rides
    82' ATC110
    85' ATC310R
    85' ATC250R
    85' ATC250ES
    16' brute force 750
    Nov 2008
    Warrenton Va
    5
    HOT STUFF!!! I figured it out. The mystery brake carrier I have is from an 84 250R!!! The 85 350X seal dimensions are 52x62x7 (mm) and the 84 250R seal dimensions are 42x62x7. I looked through enough pictures until I found this link on ebay for a brake hub that shows a good pic that looks exactly like what I have where it necks down further:http://cgi.ebay.com/ebaymotors/Honda...Q5fAccessories
    then looked on bikebandit.com and looked up the part numbers and the part numbers also showed the seal dimensions. I am going to double check the measurements tomorrow but I am pretty sure I have solved the riddle.
    Thanks for all the tips.
    Problems:
    2003 Polaris 700
    1985 Odyssey FL350
    NEVER ENOUGH!!!!
