hello
im trying to find out why my 185s has no spark,so i removed the pull start and am trying to remove the i think its called the fly wheel.the part that covers the coils do i need a special tool to get that off? if so can you make it?
hello
Yes you need a puller. I would use a generic three jawed puller from any auto part store. Download a manual and get a tester. You really should check everything else out first before going for the stator.
Hey, What other dangerously fun vehicles can I Cram in my 2and1/2-car shop? (Garage.)
hello
none of the downloads for the 185s will download for me. i was told by another member to check there first.
http://cgi.ebay.com/ebaymotors/Flywh...Q5fAccessories
motion pros are the only pullers ill ever buy again...
works on a lot of trikes too, 250r's, tri'zs, 200s, 185s...
1986 Tri-z
1985 250r
1985 200s
1985 70[/SIZE]
Don't hold me to it but I think the 200's (not the x) are the same at least for testing the ignition system. I know to test the stator you just do a continuity test off the two wires coming out of the motor. Test them one at a time to ground. One is for the lights one is for the Ignition. Test the one that goes to the cdi box.
my suggestion is a metric, left handed sky hook. but im we todd ed.
Runners:
84 200s
05 rancher
12 rancher
Right-click, save as:
http://www.freewebs.com/honda-atc185...&200Manual.pdf
Rob
Im suprised nobodys mentioned this yet, or maybe nobody knows about this trick?
Look at the wiring harness coming from the stator area, it should travel about halfway up the frame and have a connector there. There should be a 2 prong connector (usually green and yellow wires) and a single black wire. Take that black wire and unplug it, and pull back the rubber a bit to expose the metal. Hold it up to a bolt or somewhere it can ground. Dont actually touch it to the bolt, etc, just hold it close enough for a spark to jump. While you are holding the wire, have a buddy pull the engine over. If a spark jumps from the wire to the bolt/frame/whatever, then your stator is fine. If there is not spark, try a different spot, and if it still doesnt spark, then your stator is bad.
-Nick![]()
1988 Chevy Silverado 5.9L Cummins : 1986 ATC250R : 2012 Polaris RZR 570 :
98% of Americans say 'OH $#!T!!' before going into a ditch on an icy road. The other 2% are Alaskans, and they say 'Here, hold my beer and watch this!!'
The Honda 200 motors (185 200 200x) are very well known for the exciter coil going bad. They will quite completely or have a weak spark, sometimes they will even work cold bad stop sparken when they warm up.. They are around 7-12 bucks depending on where you get'em.. Its a cheap and easy fix if you have the right puller.. Like John said the 3 jaw puller aint a good idea and will most likely ruin something..
1985 250R Selveys port job and pipe
1985 70 piped for lil'freaks
2001 TRX90
ATC 90+250R+BEER= Drag Bike
1984 ATC70 Pit bike
1984 110 for sale
here is the coil you need.. http://cgi.ebay.com/ebaymotors/NOS-E...Q5fAccessories
2001 TRX90
1984 ATC70 Pit bike
1984 110 for sale
hello
thanks to every one,i downloaded the manual. tested the coil it read 185.5 not the 240 the manual said. so now need to sell atc 70 airbox so i can get the parts for my 185s. thanks again guys.
Is that what she said?what tool do i need?
sorry man couldn't help myself.
________________
https://www.mikesatvfix.com
________________
