Thread: 200e Idle's High
    louisiana
    1,499
    200e Idle's High
    I Went Through The Carb Three Times,i Let It Soak In Gas Over Night,then Cleaned Each Jet,blew The Carb And Jets With High Air Pressure And Still The Bike Is Idling High,i Tried Setting The Idling Screw But It Does Nothing,then I Adjusted The Needle Up,down.still Idles High.
    Apr 2004
    Brigham, Québec, Canada
    1,529
    Try adjusting the throttle cable. Maybe the cable is already pulling the slide up. Here's the page from the service manual.
    1984 Yamaha YTM-225DX
    Québec 3-wheeler riders group
    NE Arkansas
    2,344
    Throttle cable would be my guess too.
    My Rags
    Apr 2006
    PA
    1,464
    Throttle cable or intake leak.
    Mar 2007
    Texas
    5,045
    also did you check the slide screw? if your sitting on the trike, and you hold your right arm up, that's the right side. look at that side of the carb, and there's a screw in the side. that screw is as adjuster for idle. tien it out about 1/2-1full turn and that should help. it's what holds the slide open more for more air to pass through.
    ________________
    https://www.mikesatvfix.com
