Results 1 to 13 of 13
Thread: What is the best way to strip the paint off the engine and frame etc?
    NE Indiana
    1,067
    Just looking for ideas on stripping off the old paint in order to get the frame prepped for new paint. I want to strip the paint off my engine and I think I'm going to leave it aluminum. Maybe I'll try to polish it up a bit but I don't know where to get started on stripping.
    I remember years ago I used to have paint stripper in a can. You'd spray it on and the paint would just melt off. I'm not sure if they still make it or not, or if would be bad to use on aluminum though. Once I accidentally sprayed it in my eyes. That was awesome.
    NE Indiana
    1,067
    I remeber years ago I used to have paint stripper in a can. You'd spray it on and the paint would just melt off. I'm not sure if they still make it or not, or if would be bad to use on aluminum though.
    I have some stripper that has to be brushed on but I didn't know if it would work or not.
    Aug 2006
    NW Ohio
    1,043
    i used brush on stripper let it sit for a few minutes then used my garden hose with a spray nozzle to blast it off! worked hella great!
    ATC500AF
    Oct 2007
    Grosse Tete, LA
    3,440
    there is an orange citrus paint stripper...it work well. leave it on for 30 minutes, pressure wash, repeat...done.
    oOGoFastOo's Avatar
    oOGoFastOo is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2007
    Oregon
    265
    I bead blasted both of mine. it works good.
    NE Indiana
    1,067
    Ok, thanks for all the advise. I have a starting point now.
    Pa.'s Highest City
    8,058
    your nuts if you use paint stripper... MAKES A MESS!!!
    sand or bead blasting is the quick and easy way.....
    Nov 2006
    Ga
    103
    I agree with Chris, I have tried the brush and spray on methods and have found that it always leaves some paint behind. If you stuff your cylinder ports with rags/paper towels, and tape them up as well, the blaster is the only way
    to go. It also leaves the metal in a state where the new paint adheres nicely and is not easily scratched.
    84 Tri Zinger 60
    84 ALT 125
    84 ATC 110 (blue)
    85 YZ 490
    85 ATC 125M
    85 CR 500
    85 Tri Z 250
    85 Quadracer 250
    86 Tri Z 250
    86 ATC 350X
    (2) 86 ATC 250R
    86 Tecate 250
    87 ATC 200X
    87 ATC 250SX
    (2) 87 Big Reds
    88 Quadracer 500
    01 CR 500 (new)
    04 KX 500 (new)
    06 Banshee SE (new)
    07 CR 125 (new)
    07 CR 250 (new)
    Apr 2008
    Biloxi, MS
    149
    umm, i just got through using the brush on stripper on some atc90 forks last week and never again. bead/sand blasting is definitely the way to go. way easier. i spent another hour getting the paint that 3 coatings of the stripper left behind.
    Brad200X's Avatar
    Brad200X is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Oct 2008
    Will County, IL
    357
    Yeah, paint stripper isn't nearly as good as it used to be. I've used the same brand of stripper, and now it doesn't work as well. I think it was called Aircraft.
    Rides I own:
    '85 200X(old smokey)
    '81 ATC250R(Bassani pipe, Wiseco piston, Vesrah rod, and AMS offset rims)
    '84 KXT250 Red(the new money pit!)
    '96 KX125(FMF pipe, Boyesen reeds, One Industries graphic kit, etc.)
    '85 KX125(vintage racer. Technically it was a practice bike)
    '78 DT400(the lone Yamaha)
    NE Indiana
    1,067
    Well, I guess I can try to find a local shop that does some blasting then.
    Pa.'s Highest City
    8,058
    It isn't really necessary to strip all the paint from the frame. sand it down a bit, get all the dirt and oil off,, then primer it... sand a bit more then apply thin even coats of fresh paint.
    I never polished a whole motor before.. that involves countless hours of sanding (going from coarse to fine grade sandpaper) then alot of polishing...
    good luck...
    That aircraft stripper works about the best on smaller parts (available at walmart) but anywhere you have tight spots you'll have trouble..
