Been wrenchin on my 86 R a little bit. I totally redid the suspension on it last year. Have a PEP revalved shock, and some special guts internals for the forks (That after extensive tuning make the front forks work![]()
) But the motor was always a turd. I changed crank seals, leak down tested, played with carb, reeds, pipe, everything, it was always just a damn dog. so I took that topend off, and put this old last bore Paul Turner cylinder I had onto it. I haven't got to run it yet but it held 7psi over night so I know the crankseals and all the surfaces are good and sealed. I'll clean up most of the gasket making material before it goes back together. I've just found a lot of the times you can't get stuff to seal up good enough to pass the leak down test with just straight gaskets, you gotta get some goo on em to make it.
And yes, I know the front brake line is retarded![]()
SOON MY PRECIOUS!
