Results 1 to 7 of 7
Thread: Honda 110/90 question?
    Does anyone know if those two model (late 70's early 80's) have the same round headlight? And are misc. parts still available from Honda, like lense, trim ring, housing, switch, wire harness, etc.....? Thanks
    Feb 2003
    Delano, CA
    616
    I beleave the head lights are the same. The wire harness for my 79 110 has been D.C. from honda.
    1979 Honda 110 ATC, CEET gas tank cover, 25X11X9 rear tires
    1984 Honda 110 ATC, orignal blue plastics,
    1982 Yamaha 175 TRI-MOTO, 26MM Mikuni
    Honda US90 ATC, Collecting Dust
    2004 TRX450R
    Jun 2003
    236
    try http://www.BikeBandit.com for OEM parts...
    1984 ATC200s for sale!
    Feb 2003
    Delano, CA
    616
    http://www.powersportspro.com/
    is also good oem part finder. click on parts fish.
    2004 TRX450R
    Thank you both for the info. 8)
    I'm having trouble finding out about the two little black rubber plugs that go on the left underside of the headlight housing? Not sure if they even have plugs there? The holes are rather large and I would think water could get in without some sort of plug? But all my searching is turning up nothing? Does anyone own a 90 or 110 with the old style round headlight housing and maybe knows what the heck I'm talking about? Any help would be great. Thanks...................By the way I think the wire harness goes through on of these "plugs"
    Aug 2002
    Creswell, OR
    889
    I have 2 large holes (only) in my 79'. The one on top positioned perfectly between mounting screws is for the on/off switch. It should have 3 or more little holes around it (sorry cant remember off the top of my head)...almost straight back and slightly off center is the other more towards bottom. This is where my lighting wires feed thru. I know of no rubber plug or round thing that may or may not go here....hope that helps....you need picts hollar...
