Page 2 of 2 FirstFirst 1 2
Results 16 to 23 of 23
Thread: '81 ATC250R Complete Resto, Looks nothing like stock!
    Aug 2007
    Brookings, South Dakota
    133
    Swingarm and axle
    The swingarm wasn't bad at all, the bearings are in great shape, no wobbles, and the both the swinger and the axle are perfectly straight. Mainly it was just the looks of the setup, I bead blasted both of them and sanded the axle on the wood lathe till it was smooth, I wish I could find some PK performance plus decals again, I saved one of them, but I'm thinkin a decal company could remake me one since they can do drawings and what not. I also used that 36 tooth Sprocket specialists sprocket I just polished it.
    Attached Thumbnails Attached Thumbnails axle.jpg   swingarm in primer.jpg   swingarm done.jpg   swinger and axle.jpg   sprocket.jpg   PK2.jpg
    '81 ATC 250r: IMS tank,Uni pod filter,Keihin PJ flat 38mm,Boyesen Pro series reeds,reed spacer w/ boost bottle,milled head,bored(.080),ported,machined CR exhaust flange,and Mugen pipe.PK +3 swingarm,2+2 axle,ITP rims,and 200X fork swap w/ polished tree.
    '03 CR 250R: FMF fatty w/shorty, Pro Taper top clamp
    '85 ATC 70: 88kit, race cam, ported head, 5 angle valve job, cobra pipe, 20mm carb...
    '73 ATC 70 roller, '80 ATC 110, '86 ATC 125m, '81 XL 500s, '71 Z50, '76 Z50 W/ Lifan 125
    '84 Tecate 3
    gotballs 250r 82's Avatar
    gotballs 250r 82 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Sep 2003
    florida
    259
    lets see a pic of the swingarm and shock hook up on the bike
    82 300R tricked
    02 blaster wife's
    83 suzuki 250 dirt bike
    82 300R drag monster
    2007 suzuki hayabusa sweet street bike
    Aug 2007
    133
    Swinger and shock
    Here's the best pic I have of It.
    '84 Tecate 3
    Sep 2003
    florida
    259
    A CLOSER LOOK OF SHOCK MOUNT AT SWINGARM
    82 300R tricked
    02 blaster wife's
    Aug 2007
    133
    More Pics!
    Here's a closer pic of the swingarm and shock. Some of you were also probably wondering why I tore apart a good 3-wheeler well the answer to that is the trike was far from GOOD. The front forks were bent really bad, no front brakes to begin with, where the rear drums slid into the swingarm was so loose it wobbled like crazy, the frame broke cause it had already been welded, The silencer bolts in the frame were stripped so it was wired up and alway falling off, and pretty much everything else was zip-tied or jimmy rigged in some way so I basically started from scratch. I just figured I'd mention that cause I know how some feel about leavin things stock, but I just thought instead of replacing it with stock parts that were probably in the same shape anyway, replace them with better, newer, or aftermarket parts. The main thing that used to drive me nuts about it was when it was wide open and the silencer fell off. I'm sure many of you can relate to the sound of a 250r with no silencer "Louder than a in a tin bucket!!!"
    '84 Tecate 3
    Nov 2008
    ontario
    1,055
    you did an amazing job it now reminds me of my old 84 R, my friend has a first gen r, its a real beater fenders look like they went threw a wood chipper. still a great bike, heck he traded a junker 185 for it!
    Aug 2007
    133
    Thanks Thats exactly how the original fenders look that were on it. They go about halfway up and taper off from other ice-racers rubbin up against it I suppose.
    '84 Tecate 3
    Baltimore, MD
    6,088
    That is a pretty trick looking machine. I'm kind of partial to the wide tire fronts of the early R's though. I was kind of thrown off by the title of "complete resto" . Customized and Freshened up definitely. I remember when those first hit the showroom floors new.
