Thread: 86 250r rear skid plate
    Nov 2008
    NE Ohio
    7
    Hey Guys, Quick question.. I'm trying to get a rear skid plate on my 86 R but I have a +2 swingarm, do I need to get this custom made? Do they make a plate that will fit? I can't leave the rotor and chain/sprocket exposed to rocks....Any ideas? Thanks, Mark
    Las Vegas, NV.
    2,520
    I couldn't find any skidplate manufacturer that made skidplates for extended swingarms, so I bought a new skidplate and extended it the required amount. It seems most people with extended swingarms don't run a skidplate.
    CUYAHOGA FALLS, OHIO
    1,242
    The stock mounting is still there Mark. You should be able to mount one up. Just check the holes/threads. Any q's give me a jingle
    3-85 ATC 70
    86 ATC 250R
    86 WETBIKE
    01 KX250
    2011 KAW SXR800- 35YR EDITION
    05 HERITAGE/SPRINGER/SOFTTAIL
    Las Vegas, NV.
    2,520
    Quote Originally Posted by max View Post
    Yes, but with an extended swingarm, the parts that need protection (shock linkage & sprocket/brake rotor) are now farther apart, so a longer skidplate is necessary to protect them properly.
    Nov 2008
    NE Ohio
    7
    Max, The mounts are there but like red rider said the holes are farther apart on the swing. I'll give you a call. I'm concerned with the trail riding in the PA, lots of rocks. I'm trying to call off Jan 1st, saw you other post on Wellsville. but the odds are slim getting off in my line of work that day.
