Results 1 to 11 of 11
Thread: 82R restore: Any performance or upgrades that you can suggest?
    Shawn72's Avatar
    Shawn72 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jul 2006
    Lawton, Ok
    392
    My 82R is completely torn down in my garage at this point. It's stock other that power reeds. Are there any performance or general upgrades you can think of that I might incorporate into this build? I need some Ideas.
    It's a celebration bitches!!!
    Yamatrike400's Avatar
    Yamatrike400 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jan 2008
    MINNESOTA
    393
    Pipe, raise compression, bigger carb, porting, re-gear, the list goes on forever.
    Three Air R's
    Internet
    1,251
    reed spacer, boost bottle, look for the infamous Mugen 360 kit or a 300r kit. Don't forget suspension - new modern rear shock, 300ex hubs for a wider stance, maybe do the 200x front end conversion to run a taller, narrow front tire.
    Jul 2006
    Quote Originally Posted by Saul View Post
    boost bottle...... JUNK!
    mugen 360? thats nearly impossible to find + big money
    300R kits not that bad
    BIGGER CARB or better yet a carb from a 85-86 250R is a great upgrade!
    PORTING! best mod!
    possible DG sunburst head
    Hampton, Virginia, C.S.A.
    2,664
    on a restore i think putting a complete 200x front end would take away from the purpose of restoring it...that would probly be a cool upgrade tho if thats all you wanted to do is upgrade the bike
    current rides
    82' ATC110
    85' ATC310R
    85' ATC250R
    85' ATC250ES
    16' brute force 750
    Tionesta, PA
    5,747
    Get an aftermarket pipe of some sort - those stockers choke the power back big time. Even with a stock carb - once you swap pipes - HUGE difference.
    Groundworx's Avatar
    Groundworx is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Tuttle Oklahoma
    421
    Porting and polishing the cylinder will get some noticable gains. Pipe should help too if they are not too hard to find. I don't know about the older R's.
    Many quads for sale. 400EXs, Z400, 450s ect.
    Aug 2007
    Brookings, South Dakota
    133
    Well about all I can tell ya is to check out my 81 resto post, I've done quite a few of all upgrades available for the 1st gen R's, it should be on page 2 of this forum. One thing I would keep an eye out for is a boost bottle, many believe they only work on twins, but yamaha used them factory on alot of their older bikes. As long as you have the correct volume of bottle and its setup right it's definately noticeable. It helps reduce pulsing in the carb to keep a steady flow and gives you a boost of fuel/air right off the bottom and even aids in over-rev. If you like the throttle response of 2-strokes stock you should throw on a flat slide carb and a boost bottle( way better!) The reason I mention this is they're usually cheap if you can find them and they are simple to install just google boost bottle and check out some of the sites on how they work.
    '81 ATC 250r: IMS tank,Uni pod filter,Keihin PJ flat 38mm,Boyesen Pro series reeds,reed spacer w/ boost bottle,milled head,bored(.080),ported,machined CR exhaust flange,and Mugen pipe.PK +3 swingarm,2+2 axle,ITP rims,and 200X fork swap w/ polished tree.
    '03 CR 250R: FMF fatty w/shorty, Pro Taper top clamp
    '85 ATC 70: 88kit, race cam, ported head, 5 angle valve job, cobra pipe, 20mm carb...
    '73 ATC 70 roller, '80 ATC 110, '86 ATC 125m, '81 XL 500s, '71 Z50, '76 Z50 W/ Lifan 125
    '84 Tecate 3
    Jan 2008
    MINNESOTA
    393
    Yeah both of my Yamaha IT's have boost bottles. It is a proven technology that works good if set up right.
    Three Air R's
    Jan 2004
    NJ
    1,646
    Start with a engine that has at least 150 psi. Then do your mods.
    3 CR500R's and counting. Do I really need 4???
    Do I really need 9 Tigers?
    Laegers ATC500R
    DO NOT send any thing to whats his face (dirt-face/crasher) here on the board. What a scum bag. He screwed (stole) money from me and screwed me on my ME360 and Hondaline 300R engine rebuilds.
    Nov 2002
    Chezzetcook Nova Scotia
    1,838
    Funny you say that. I just finished my 82 and it had 150 psi. My 1985 tecate had 210. Will a 85-86 atc 250r carb bolt on with no serious rejetting?
    1985 KXT 250 Tecate
    1983 KX 250
    Proud member of
    3wheelerworld.com
    3wheeler.org
    Planettrike.com
    Airfoolers.com
