Results 1 to 10 of 10
Thread: 84 200ES Clutch Slipping
    Oct 2008
    Angleton, TX
    44
    The clutch slips when I gas it in 4th gear. Is there anyway I can adjust it or do I just need to replace it?
    I've had:
    '85 ATC 125M
    '83 ATC 110
    Now:
    '84 200ES BIG RED
    Howdy's Avatar
    Celina, Ohio
    10,079
    Does the motor have to really be rev'd up for the clutch to engage? Or does the motor want to rev up without the machine taking off?
    Howdy
    Oct 2008
    Angleton, TX
    44
    The clutch will engage if I ease on it, but if I on it it starts to slip.
    I've had:
    '85 ATC 125M
    '83 ATC 110
    Now:
    '84 200ES BIG RED
    Oct 2008
    NB, Canada
    852
    My 200m does a similar thing. There are two clutches, but I don't know which one is slipping, and only one can be adjusted.
    Rides:
    1985 250sx
    1982 ATC185s
    1984 200es
    Always Hoping For a Maritime Trikefest- http://www.3wheelerworld.com/showthr...s-where-you-at
    "Wear Limits Are Just A Suggestion"
    Howdy's Avatar
    Celina, Ohio
    10,079
    Quote Originally Posted by DILLIGAF View Post
    That info tells me the Primary clutch is going bad. If the machine would take off at high RPM's then that tells me the centrifical clutch is bad.
    Howdy
    leokendall is offline At The Back Of The Pack Arm chair racerFirst time rider
    May 2008
    corner brook, Newfoundland, Canada
    180
    are you sure your not trying to start the bike in to high of a gear.
    what kind of oil are you using?
    1984 Honda Big Red
    Oct 2008
    Angleton, TX
    44
    It don't have much in the way of brakes so I downshift and start from 1st gear. I need to get the brake situation fixed also, but I can handle that. So if its not the centrifigul clutch, can I adjust the other? I am using Pennzoil 10w40. The oil was low, but I didn't notice it til after I already rode it for about 15 minutes. I feel like an idiot for not checking it first, but theres nothing I can do about it now.
    I've had:
    '85 ATC 125M
    '83 ATC 110
    Now:
    '84 200ES BIG RED
    Howdy's Avatar
    Celina, Ohio
    10,079
    There really isn't any adjustment to either clutch on this and simular machines. The adjustment eveyone talks about is for the clutch dis-engager connected to the shift. The adjustment works to disengage the clutch while shifting between gears.
    What does this mean / what is the bottom line? If your clutch is slipping then it needs to be replaced.
    Howdy
    May 2008
    180
    You can take the clutch out and sand the clutch plates a lil. might get ya movin a bit longer but it will not last. New plates and springs are the way to go.
    1984 Honda Big Red
    Oct 2008
    NB, Canada
    852
    I found how to adjust the clutch on the 200s, which should be very similar as the 200es. First you lossen the locking nut for the clutch adjustment on the side, then turn the screw all of the way out until it stops. Turn the screw in 1/4 of a turn, and tighten the locking nut.
    Rides:
    1985 250sx
    1982 ATC185s
    1984 200es
