Results 1 to 8 of 8
Thread: 70 Tech Help! Boggs under throttle
    VABCH350X is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2003
    Whidbey Island, WA
    322
    Sorry for the long post, but this thing has been kicking my butt. TRX70 starts and runs well, but boggs when given WOT. It will wind out if given throttle slowly, but seems to lack power.
    Takes WOT on choke, which might indicate a clogged jet, but both jets have been replaced and carb cleaned multiple times, all passages clear. Also installed a carb rebuild kit, and swapped out carb bodies with another used one. No joy.
    Exhaust smells rich, and plugs sometimes carbon-foul, but the fact that it takes WOT on choke should indicate a lean condition. I'm kinda confused and hoping someone else has conquered this problem on the Honda 70 and can help.
    Timing looks good, and valve lash is set properly. Is it possible that a valve seat is bad or compression is low? Would either of those conditions cause these symptoms? Thanks a lot for any help.
    -Paul
    86 Honda ATC350X
    86 Honda TRX70
    02 Honda TRX400EX
    03 Kawasaki KFX80
    82 Honda CB900F
    NE Arkansas
    2,344
    You need to bump up the main 1 or 2 sizes. Both of mine did the same thing till I put bigger mains in.
    My Rags
    Apr 2004
    Brigham, Québec, Canada
    1,528
    When you say to put a one size bigger jet, let say that the current jet is a 110 is the bigger one 111 or 115?
    1984 Yamaha YTM-225DX
    Québec 3-wheeler riders group
    Aug 2003
    Whidbey Island, WA
    322
    I think the current main is a #62, I'll see what I can find at the Honda shop. This would explain the fact that it feels starved for fuel. Any idea why it would carbon-foul the plug?
    86 Honda ATC350X
    86 Honda TRX70
    02 Honda TRX400EX
    03 Kawasaki KFX80
    82 Honda CB900F
    Aug 2003
    Whidbey Island, WA
    322
    86 Honda ATC350X
    86 Honda TRX70
    02 Honda TRX400EX
    03 Kawasaki KFX80
    82 Honda CB900F
    Jan 2004
    Strongstown, Pa
    548
    Are your points set?
    Can't or Won't?
    Aug 2003
    Whidbey Island, WA
    322
    CDI Ignition on the TRXs. Got a handful of jets from my friendly local Honda dealer and set to work. Went up to a #65 (from 62) with a new pl;ug, and the bike ran horribly, fouled the plug in the first 30 seconds. I went back to the stock setup (#62) and blasted out all the carb passages yet again, and the bike runs OK. If it's hot (e.g: after blasting down the road wide open) it will take throttle off idle, but not otherwise.
    All the jets I grabbed at the dealer were bigger...perhaps I should be goiing smaller. Thoughts?
    86 Honda ATC350X
    86 Honda TRX70
    02 Honda TRX400EX
    03 Kawasaki KFX80
    82 Honda CB900F
    KASEY's Avatar
    ARIZONAS BIGGEST TROUBLEMAKER
    4,239
    have you looked at a jetting chart? changing the main does NOTHING for the lower spectrum of the throttle position,,,, and thats where you are probably starving for fuel,,,, try 2 sizes larger pilot and raise the needle... your probably not getting enough fuel in the midrange to run right ,,,,,,,,,, i just rejetted a trx70 tonight and it runs PERFECT ... the needle had to go up 3 notches to run so i did a little reshaping of the taper to get a little more midrange fuel.... it was way to lean,,,,
