Thread: bad throttle response help.
    Apr 2003
    Bay Area CA.
    2,638
    My atc70 has bad throttle response when i give it gas to go in 1st gear it runs about half a second to a second after i push the throttle. whats going on?
    1985 350x
    1985 atc70
    2006 ltz400
    2017 z125pro
    Jun 2003
    11
    could be many things
    could have choke on
    could have clogged exhaust
    could have clogged intake/air filter
    could have damaged reeds
    Gas screw could need an outward turn or two on carb
    Points could be gapped too widely
    Just look for all those things, you'll probably find the problem, hopefully!
    Jun 2003
    11
    How old is the carb?
    The screw in the bottom center of the carb bowl that surrounds/connects to the main jet is hollow and should have a smal hole or slits in the bottom of it to allow gas in and up the main jet. Check to see if it is all gummed up.
    Apr 2003
    Bay Area CA.
    2,638
    Im pretty sure its the gas screw, but it has two, which one is it?
    1985 350x
    1985 atc70
    2006 ltz400
    2017 z125pro
    Mar 2003
    472
    Re: could be many things
    Quote Originally Posted by piratepowwow
    no it couldent its a 4 stroke! lol
    1985 Tecate restoration project-R.I.P
