I need some rear end parts for a 07 250 big bear (yamaha)
https://www.bikebandit.com/partsbandit/basket.asp
thats a linc to the list of parts i need
if you can beat that I will buy!
you can't post like that syko....doesn't show what was in your cart.
does for me, even after I restarted my comp and cleared out my history...
edit anyway I need this for a 07 big bear 250
alll rear end bearings and seals
rear brake shoes
left rear hub
unless you went in and deleted every temp file...it'll work for ya. lol.
I lost my price book for my catalog...I've been ordering stuff blind to be honest. sorry I couldn't help.
How much will all of it cost you from them?
I think people forget that we are a parts dealer....
Proudly NOT a member of
"Team on the Teat"
well give me a price there mister partsy pants![]()
its deffinatly a 07 big bear 250
edit used hub is fine as long as the splines are mint
have you checked with servicehonda.com ?
Rides
85 ATC350X
85 ATC200X
You must not deal with servicehonda.com then. They now sell parts for about every make and model. True 1 stop shopping.
Howdy
well now I need to go back to bed...
my bad
carry one then.
Ok found everything I think
These are all the OEM prices.
Except the brakes.
I can get you the brakes for aftermarket EBC for 32.95
I found I according to Yamaha cross reference, that 2006 Bigbear 400, takes the same rear bearings and seals.
All balls shows no aftermarket kit for your bike,but they do for the 2006 bigbear 400
If they are the same,I can get you a All Balls kit for $28.95,2 bearings 2 seals.
The hub would be 45.00 brand new Probably $30 used from my salvage yard.
Here is the OEM parts prices.
If you want all OEM stuff new, I could get
All the stuff I looked up shipped to you for about 125.00(without brakes)
Check this link and make sure I have everything looked up you need.
https://www.onlinemicrofiche.com/WPS...t/Viewcart.asp
So aftermarket parts with a used Hub would be.... 100.00 plus about 10 bucks shipping to
you(with brakes).....I am not completely sure on the All balls kit fitting your bike.I would have to call them Monday and check.According to Yamaha they will interchange.
Or OEM New parts with EBC brakes would be about 158.00 shiped to you. A few bucks cheaper than Bike Bandit.
"Team on the Teat"
Ok let me get with him then the oem price is about 25 dollars cheaper then everything off bike bandit and the aftermarket is most likely the way hes going to go.
ok add this to a seperate list 1997 honda trx 300 2wd forutrax
air filer can be uni or aftermarket
oil filter
starter
rear brakes
and a air filter for a 02 400ex
I need those prices asap as well, I will get with you tonight or monday on parts ordering, can I pay pal you?
I will look into those also.
yes paypal works!
"Team on the Teat"
