Thread: How do I know if I need a new float valve?
    Jul 2002
    El Paso, Texas
    512
    My 84 Big Red will start on the first pull, run for about 5 seconds, then die. After that I can't start it again. I think it is flooding. Would that be the float valve?
    Honda
    86 350X - Full Restomod
    85 250R - Legend
    85 Big Red - Clean Original
    85 Big Red - Custom
    Not Honda
    85 Yam Badger 80 - Kids
    99 Pol Sport 400 - Got it FREE
    Oct 2008
    NB, Canada
    852
    If it is the float, after it sits a little while with the gas on, gas should come out of the carb and/or overflow hose. I could also not be getting enough gas. The float could be sticking up, and not letting gas in quick enough.
    Rides:
    1985 250sx
    1982 ATC185s
    1984 200es
    Always Hoping For a Maritime Trikefest- http://www.3wheelerworld.com/showthr...s-where-you-at
    "Wear Limits Are Just A Suggestion"
    Mar 2007
    Texas
    5,045
    the carb could be dirty or fuel filter clogged.
    ________________
    https://www.mikesatvfix.com
    Apr 2006
    Crestview, Florida
    2,429
    Next time it does it pull the spark plug out immediately and see if its wet. If its dry you are running outta fuel. Clean the petcock and take the carb apart and clean every part real good.
    Rides
    85 ATC350X
    85 ATC200X
    Nov 2006
    southern oregon
    2,338
    Just replace it... a worn needle can stick open or shut...
