Page 2 of 2 FirstFirst 1 2
Results 16 to 21 of 21
Thread: 2 honda trikes... help identify...
    Sep 2008
    KS
    45
    Here is the code off of the engine, can someone decode it for me?
    TB05E-2208555
    Jason
    Apr 2004
    Brigham, Québec, Canada
    1,529
    1984 Yamaha YTM-225DX
    Québec 3-wheeler riders group
    Sep 2003
    Elizabethtown PA
    1,581
    i dont know the codes BUT
    the one with the front suspension is a 83 atc200 since it has the 25" tires. they wont fit on a 200s will rub fenders
    the other one with solid front end is a 81 or 82 atc 200 since it has red plastic. the 80 atc185 was orange colored so it's not that.
    niether one is a 200s
    JASON LISKEY
    2 = 86 atc 350x's
    86 atc 250r
    Sep 2008
    KS
    45
    Quote Originally Posted by Yamada View Post
    that is what i came up with too... just wanted some confirmation! LOL
    now i can get parts for it... when i picked it up the guy started it (push started) and it ran fine but poured black smoke... today i strapped it to my little 70 and pulled it a couple hundred feet and then back and couldn't get it to even try to fire, instead of messing with it much more i'll just pull the motor and rebuild it and go from there, also rebuild the carb (leaks gas from around the bowl) and the rear brakes do not work so i'll redo that too... i guess it'll be my winter project.
    The roller i might use the rear end and brake setup and build a go cart using a honda 110 engine/tranny and keep the rest for parts...
    Jason
    Sep 2003
    Elizabethtown PA
    1,581
    Quote Originally Posted by oneclick View Post
    Jason
    if there is alot of black smoke coming out the exhaust it probably just has carb problems running real rich. It mite not even need the motor rebiult. just do the carb 1st and see what happens.
    JASON LISKEY
    2 = 86 atc 350x's
    86 atc 250r
    Groundworx's Avatar
    Groundworx is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Tuttle Oklahoma
    421
    You can look on the neck of the frame. If the VIN is still there, you can look at the 10th digit and figure out the year of the frame.
    Many quads for sale. 400EXs, Z400, 450s ect.
