i was checking the timing on my 200x and when i took the plug off the side of the motor while it was running and i notice alot of air comming out. when i reved it up i noticed that it did not get any faster or anything. this is the first time i have been into a 4 stroke atv motor. i was just wondering if that is normal. i had a misshap with the timing gear on the cam a few weeks ago and i dont think i bent a valve cause it is a trailprotrailprotrailprotrailprotrailpro to kick start. lots of compression. itr seems to run strong but i was just concerned. i know that there will be pressure from the piston travel. thanks
t-man
